Problem in Importing CFX results in Tecplot 360-2012 |
October 11, 2013, 03:45 |
Hamed
Rep Power: 17 |
Dear friends:
In fact I want to importing CFX results in Tecplot 360-2012 and my file is about 3 GB size and the importing can not be performed due to big size, can anybody help me please? BEST |
October 11, 2013, 07:43 |
Rep Power: 144 |
Why can't the importing be done? What cannot handle the big file? What importing technique are you using?
October 11, 2013, 07:57 |
Hamed
Rep Power: 17 |
Dear ghorrocks
Tecplot shows an error that has not enough memory. I try to import from the bottom path: File->load data files->Ansys CFX-> *.res |
October 11, 2013, 08:04 |
Rep Power: 144 |
Do you have the 64 bit version of Tecplot installed? Are you on a 64 bit OS?
October 11, 2013, 09:34 |
Dave
Rep Power: 15 |
Hi Hamed,
If you import your CFX results into Tecplot 360 as a .CGNS file you can select what specific zones and variables you want to import. This may allow you to get around any memory issues. You can generate a .CGNS file using the "Tools -> Export Results" menu in the ANSYS CFX solver manager. Also, there is a forum called Tecplot talk (www.tecplottalk.com) where you could ask advice if your still having problems. I don't know how active the forum is at the moment, but Tecplot staff/developers used to reply to posts quite frequently. Good luck, Dave |
October 11, 2013, 10:05 |
Hamed
Rep Power: 17 |
In fact I am using a 32 bit Tecplot with a 64 bit OS. Best |
October 11, 2013, 10:06 |
Hamed
Rep Power: 17 |
Dear Glenn Horrocks
October 12, 2013, 07:29 |
Rep Power: 144 |
Well, there you have the explanation of your problem. You need to get the 64 bit version of tecplot. You are currently limiting the size simulation you can display by using the 32 bit version.
How to plot contour lines in Tecplot 360 using Excel file | Iqbal | Tecplot | 1 | May 30, 2012 20:22 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Problem importing watertight model into CFX | djk1301 | ANSYS | 3 | February 1, 2011 23:04 |
CFX vs. Fluent Results | n.sharifi | CFX | 8 | November 3, 2010 17:40 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 13:48 |
