October 8, 2013, 15:30 |
Basic heat definition question
Rep Power: 12 |
I have been doing conjugate heat transfer problems on cfx and I have been defining heat generation on my pipes using the subdomain feature. I select all the pipes in the subdomain and specify source as 1000 W/m3. My question is, do all the pipes get 1000 W/m3 or does 1000W/m3 get divided equally among the pipes which I have selected. I think it gets 1000W/m3 each, but I just want to make sure. Thanks for reading. |
October 8, 2013, 17:51 |
Rep Power: 144 |
Make sure you understand the unit - it is W/m^3. So it is a heat source per unit volume, which means whatever you select will get the same heat source per unit volume applied all over it. It does not get "split up" - that is not meaningful for that unit.
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Theoretical question. Heat flux from the wall in Fluent. | MaxakCh | FLUENT | 0 | October 16, 2012 06:46 |
[Other] very basic question about createPhi.H | feldy77 | OpenFOAM Meshing & Mesh Conversion | 2 | November 22, 2011 08:16 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
New to CFD with some basic question | Newbie | Main CFD Forum | 3 | October 23, 2006 12:22 |
