How to set Reynolds value in Ansys 14.0
Old   September 26, 2013, 07:25
Exclamation How to set Reynolds value in Ansys 14.0
ferdy is on a distinguished road
Hello everybody!
I kindly ask you all if somebody knows if there is a way for setting a particular Reynolds value in Ansys 14.0 (noncommercial use), and if it was affermative, what steps I have exactly to follow to set it.
Thank you in andvance for helping me.
Ferdy
ferdy is offline   Reply With Quote
Old   September 26, 2013, 09:28
Lance
Lance is on a distinguished road
CFX is a dimensional solver, so there is no way you can enter a Reynolds number directly. You can obtain a specific Re by setting boundary conditions and fluid properties, but since you havent described what you are trying to do we cant help you.
Lance is offline   Reply With Quote
Old   September 26, 2013, 10:12
Thank you for the reply.
Actually the problem is that we are studying a flow of air in a channel at constant temperature, we have got this inlet conditions at the entry of the channel:
Re = 80.000
characteristic length (h) = 0,05 m
kinematic viscosity (v)=1,5*10^-5 m^2/s
inlet velocity (u)=24 m/s
The problem is that this value of the kinematic viscosity of the air at pressure of 1 bar should correspond at a temperature that lies between 16 and 17 °C, but automatically Ansys has got only air at 25°C in its library of fluids, or water, or ideal gas. I hope this is not a restriction because of the fact we are using a noncommercial version of Ansys (student version).
If there is a way of modifying the tempearture of the air from "default domain" -> basic settings -> "fluid and particle definition" we should be able to upload a new fluid (add new item) but we don't know how to do this.
Thank you very much.
Old   September 26, 2013, 10:29
Lance
so.... your question boils down to how to create a new material?
See any of the tutorials on how to change/modify material properties. It is straightforward. I doubt that the student version has a restriction on creating new materials.
Old   September 27, 2013, 10:26
Thank you!we have been able to solve our library problem...thank you...
the DEFINE_MASS_TRANSFER is only a interpreting udf IN ANSYS 14.0 fangdian Fluent UDF and Scheme Programming 7 April 19, 2016 04:53
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
i am a novice to cfd..can anybody set guidelines for me to ANSYS? abhishektomar11 ANSYS 0 February 6, 2011 11:24
Installation problems indy OpenFOAM Installation 7 April 3, 2009 10:40
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
