September 14, 2013, 18:11 |
Geometry Scale in CFX
Ali Sarami
Rep Power: 16 |
I have imported a mesh from ICEM to CFX and noticed that the dimensions are multiplied by some factor. Would you please help me scale my geometry in CFX-Pre? Cheers Ali |
September 15, 2013, 07:49 |
Rep Power: 144 |
Use the transform geometry option. You can scale, translate, rotate geometries with this tool.
September 15, 2013, 11:14 |
Ali Sarami
Rep Power: 16 |
September 15, 2013, 19:12 |
Rep Power: 144 |
You can translate in ICEM or CFX-Pre. They both have the option.
February 7, 2020, 15:14 |
Sebastián A.
Rep Power: 9 |
February 7, 2020, 17:25 |
Rep Power: 33 |
During mesh import you should be able to select the units for the mesh, so CFX-Pre can scale it properly.
After the mesh has been imported, right click on the mesh icon, and select Mesh Transformation, and use the scaling option.
expression error with icem geometry scale in re-meshing | MUMMED | CFX | 0 | May 19, 2013 12:54 |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 03:20 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 06:59 |
CFX Post - Inserting additional geometry | Andrew | CFX | 2 | April 18, 2007 09:27 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
