Wind turbine simulation in Ansys CFX
Like Tree3Likes
Old   June 24, 2016, 06:28
Default wind turbine rotor simulation
  #41
sattar
drsattar is on a distinguished road
Dear all
I did simulation for wind turbine rotor which contain from stationary and rotational domains
how can I check from the results that the big domain (stationary domain )size is suitable and have no bad effects on the simulation
drsattar is offline   Reply With Quote
Old   June 24, 2016, 07:39
Do another simulation with the stationary domain boundary twice the distance away. If it is not any different to your first case then your first case is fine.
You can also do this by halving the distance as well, providing that you think you are bigger than you need.
Old   June 27, 2016, 02:55
sattar
Thank you very much, actually that what I did
Old   September 29, 2016, 00:27
Default How to specify a range of RPM for wind turbine simulation
  #44
Mujahid Badshah
mujahidbadshah is on a distinguished road
I want to obtain Cp at different Tip speed ratios from my wind turbine simulation. can any body tell me how to specify a range of RPM from 100 to 200 rpm to obtain several values of Cp in a single simulations. Is it possible or I will have to run multiple simulations (i.e., one simulation for each rpm value).
mujahidbadshah is offline   Reply With Quote
Old   September 29, 2016, 01:52
fresty is on a distinguished road
Have a look at parameteric setup tutorials...
fresty is offline   Reply With Quote
Old   September 29, 2016, 01:56
Mujahid Badshah
thanks fresty. I will look into the parametric setup tutorial and then share the outcome.
Best Regards
Old   September 29, 2016, 02:21
Mujahid Badshah
Hi fresty,
Sorry for the incomplete information in the initial post. I am using Ansys CFX. I have found nothing like the "parametric setup" in the cfx tutorials. Although, a tutorial on parametric analysis is available in the Ansys fluent but those information are not helpful for the cfx simulation.
Old   September 29, 2016, 07:19
Yes, parametric analysis is what i tried referring to.. You've certainly missed something in the tutorials, as Parametric Analysis is independent of the module one uses (assuming you're using ANSYS Workbench)... have a look at some videos on the same, you would find it easier than you would imagine..
As a quick summary, in CFX-Pre the Angular Velocity has to be entered using an expression.. that expression could then be selected as Workbench Input Parameter... in CFX-Post the desired output variables could then be selected as Workbench Output Parameters..
Old   September 29, 2016, 11:41
Mujahid Badshah
Hi fresty,
Thanks for the reply. I will rephrase my question. I want to find out the power of my wind turbine at different rpm say at 100, 120, 140, 160 and 190 rev/mint. Can I do it in a single simulation or I will required multiple simulations one at each rpm.
Best Regards
Old   September 29, 2016, 13:33
You would have to run multiple simulations, each at a single RPM.. hence, a parametric setup would work out quite well for such scenario...
Old   January 18, 2017, 13:02
Mujahid Badshah
Originally Posted by Kutan View Post
Hi Alejandro,
What have you changed in your model? How did you managed to get accurate/suitable results for your wind turbine? At the moment, I have the same problem with my analysis and don't know what is the reason. For low roational speed and lower velocities it gives correct results, but design wind speed and rotational speed I get Cp around 300%. Could you please help me?
Thanks in advance.
Best Regards,
Kutan
I also have the same problem. Kutan and Alejandro kindly tell me how you managed to solve this problem. Glenn, I have cross checked the list that you have referred but apparently, there is nothing wrong with this simulation. Almost every one in the wind turbine simulation have faced this problem but none has shared the solution to the problem. A solution to the problem will help a lot of forum members.
Best Regards
Mujahid Badshah
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
[ANSYS Meshing] 3d wind turbine mesh for multiphase simulation mingersai ANSYS Meshing & Geometry 0 January 17, 2012 19:20
2D Simulation of Savonius Wind Turbine ravindersingh FLUENT 4 December 9, 2011 14:00
[Other] ANSYS CFX-Meshing problem of a wind turbine blade Zoe ANSYS Meshing & Geometry 1 July 14, 2010 03:02
wind turbine simulation moca CFX 1 July 25, 2009 07:48
