September 5, 2013, 23:35 |
interface doubt
Shashwat
Rep Power: 15 |
Dear all,
I have a doubt in the domain interface tab (fluid-porous), I found the following option. interface model>option >pressure change What is exact meaning of it? for example, I just put the default value of 70 mmHg. Can you please explain the theory of it? I set fluid domain initialization as 89 mm Hg . is it correct the porous domain pressure is 19 mm Hg? if this is correct , we can put the porous domain pressure initialization as 19 mmHg instead. Thank you |
September 6, 2013, 11:34 |
#2 | |
Bruno
Rep Power: 21 |
With the tab 'Addition Interface Models' opened, hit F1 on your keyboard.
This should be used to model local pressure losses (a screen, for example) or to fix the pressure loss on a periodic translational domain, not to model the pressure loss across a porous domain. For that you should use the porous domain loss model. Cheers. |
September 7, 2013, 02:35 |
#3 | |
Shashwat
Rep Power: 15 |
Thank you so much. Regards. |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
