Xeon X5690 problem
Old   September 2, 2013, 04:13
Default Xeon X5690 problem
Jinwhan Ryuk
Whitebear is on a distinguished road
I am mainly using ANSYS Workbench and ANSYS CFX environment. Intel (R) Xeon CPU X5690 is very slow especially loading and meshing file. Does anyone have the same problem with me? How could I solve this problem?
Whitebear is offline   Reply With Quote
Old   September 2, 2013, 08:55
If the file is big then you have to expect a long load time.
Loading files is also related to the hard drive and/or network speeds. Also virus checkers can cripple it. Meshing is mainly a function of CPU speed, but hard drive speed can be important if it is using swap memory. Also, the latest versions of CFX are faster then older versions. Which version of CFX are you using?
Big CFD simulations (including the setup of them) are slow and take lots of time.
Old   September 9, 2013, 00:34
Smile Thank you very much
Jinwhan Ryuk
Thank you very much for your reply. I use Workbench 14.5.7. The best way that I chose is to change hard disk drive. But I don't know the definition of big file in ANSYS CFX. 1Gbyte or 500Mbyte?...
Old   September 9, 2013, 02:00
CFX uses many different files throughout the simulation process. Which file are you referring to?
[Other] engineFoam new mesh problem ayhan515 OpenFOAM Meshing & Mesh Conversion 5 August 10, 2015 09:45
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
