September 6, 2013, 21:22 |
#21 |
liuzexiang
Rep Power: 14 |
please give me some advice!!
September 8, 2013, 07:26 |
#22 |
Rep Power: 144 |
I have nothing to add beyond what I have already said. Until you consider my previous suggestions I see no point making more suggestions.
September 11, 2013, 00:21 |
#23 | |
liuzexiang
Rep Power: 14 |
Run mode: partitioning run Host computer: MK-PC (PID:788) Job started: Wed Sep 11 10:45:40 2013 Details of error:- ---------------- Error detected by routine PSHDIR CDRNAM = ../../JCONT CRESLT = NONE Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/EQUATIONS/JCONT_FL2/TERM1 ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR An error has occurred in cfx5solve: | | | | The ANSYS CFX partitioner exited with return code 1. |
September 11, 2013, 07:09 |
#24 |
Rep Power: 144 |
This error says you missed a fundamental part of the multiphase setup -but I cannot tell exactly which. I would check the multiphase setup again.
You could also post the output file with the CCL and error included. |
September 11, 2013, 13:57 |
#25 | |
liuzexiang
Rep Power: 14 |
the mistake is : No data source for Workspace, cannot monitor Solver data. Last edited by liuzexiang; September 11, 2013 at 15:03. |
September 11, 2013, 14:21 |
#26 |
liuzexiang
Rep Power: 14 |
the rotation simulation is done when i set both of the symmetry area of the tool domain and fluid domain are domain interface and the rotational periodicity is set in the Interface Model. the connecting areas between tool domain and fluid domain, workpiece domain and fluid domain is set frozen rotor in the Frame change/Mixing Model. The electrimagntic model is set in the tool domain ,fluid domain and workpiece domain respectively. when the fluid contains only the brine,the simulation is finished without error, but when the gas (air at 298k) is contained in the fluid, the mistake appear such as above. i check the set in the simulation for many time, but i can not find the reason. Please tell why.
Anther question : I do not know the really situation as the simulation, in my opinion,when the tool rotats in the fluid domain, that is to say it stir the fluid,so there must be change in the pressure and the velocity of the fluid. But i can not find the change in the simulation,so i can not believe the result of the simulation. Maybe the set of the domain interface is wrong,such as the Mass And Momentum, i try the Free Slip wall or No slip wall. but the result is no change. Is the method for the rotation simulation right? |
September 11, 2013, 14:48 |
#27 |
liuzexiang
Rep Power: 14 |
there is the pressure of monitor point in the fluid domain.
September 11, 2013, 19:42 |
#28 |
Rep Power: 144 |
This is a very complex model and I do not have time to debug it for you.
All I can recommend is to build the simulation up piece by piece. Can you run a cavitation model without electrics, rotation and moving mesh? Once that is working, add the physics one bit at a time to build up to the full model. |
September 11, 2013, 21:19 |
#29 | |
liuzexiang
Rep Power: 14 |
September 14, 2013, 10:00 |
why ?
#30 |
liuzexiang
Rep Power: 14 |
why is the result?
the rotation simulation is done and the tool domain is set as rotation with speed 600rpm the explation of the pictures. the model (picture 1): 1 is the interface of the tool domain and the fluid domain at the inside of the hole of the tool , the set:interface model: General Connection,Frezon Rotor; the interface side in fluid domain is set No slip wall, and the wall velocity is rotating wall :-600 rpm 2 is the interface of the tool domain and the fluid domain at the outside of the hole of the tool, the set is the same as 1; 4 is the interface of the tool domain and the fluid domain at the bottom of the domain. the set is the same as 1; 3 is the interface of the workpiece domain and the fluid at the side of the hole of the workpiece, the set interface model:General Connection,Frezon Rotor; the interface side in fluid domain is set No slip wall, but the wall velocity is set as 0 rpm; 5 is the interface of the workpiece domain and the fluid at the bottom of the hole of the workpiece, the set is the same as 3. the quesetion is : 1. when the velocity contour is gained ,why is zero(the blue) for the velocity at the surrounding of the tool ;(the blue) in picture 2 2. when the velocity coutour is gained,there is no change for the velocity in the direction. in my opinion maybe is the swirl, and the direction of the velocity should be changed. the tool: outside diameter 1.2mm, the inside diameter:0.8mm the hole in the workpiece :diameter:1.6mm |
September 14, 2013, 10:24 |
#31 |
liuzexiang
Rep Power: 14 |
is the set of the rotation wrong? or for there is no change for the too small tool in the fluid simulation.
other questions: 1.such as this kind of rotation simulation,the tool domain is set as fluid in many similar example. what is the difference between the fluid domain and the solid domain. the simulation when the tool domain is set as the fluid domain, the result is different, and the velocity surrounding the tool domain is not zero. why? 2.Is the CFX suitable for the simulation with two-phase flow and electromagnetic model? i try for many times, but failure. Thank you very much! |
September 15, 2013, 07:53 |
#32 |
Rep Power: 144 |
I say again - This is a very complex model and I do not have time to debug it for you.
But I can see in your contours that it looks very blocky. This suggests you have a very coarse mesh. You will not get very useful results with such a coarse mesh, a far finer mesh is required. |
September 15, 2013, 11:12 |
#33 | |
liuzexiang
Rep Power: 14 |
September 16, 2013, 03:50 |
#34 |
Lance
Rep Power: 22 |
Then get a bigger computer. There is no point in doing such a complex simulation if you cannot resolve the flow. You are only wasting your time.
September 16, 2013, 09:12 |
#35 |
liuzexiang
Rep Power: 14 |
rotation and vibration |
