Surface tension problem in CFX
Old   August 27, 2013, 10:52
Question Surface tension problem in CFX
LE Fuliang
lefuliang is on a distinguished road
I am gonna simulate a viscous source flow that going across bumps. The wall of bump is no slip wall and adhesion force should be considered on these bump walls.
The boundaries is shown in fig.1, and the Pre-setting is listed as follow:
1. fluids: two continuous fluid (air, fluid 1:another is viscous fluid 0.8Pa.s), no bouyant;
2. fluid models: standard free surface/homogeneous model, laminar flow, no heat transfer, no combustion;
3. fluid pair models: air|fluid 1, surface tension coefficient:0.033 N/m, continuum surface force, primary fluid: fluid 1, no interphase transfer, no mass transfer;
4. inlet source: fluid 1: 2.6 mg/s;
5. bump wall: no slip wall, wall contact angle: 20 deg;
6. other walls: free slip wall, no wall adhesion;
7. open: static pressure: 0 Pa, normal to boundary;
8. Analysis type: transient, total time: 5 s, adapative timesteps, min timestep:0.0001 s, max timestep: 0.1s;
The solver finished very soon, but the result is totally wrong as fig.2 at 5 second simulation time. The fluid 1 almost stayed in same position as fig.2 during different timesteps and not yet passed one bump, whereas experiment will almost fill the domain.
I really spent plenty of time to find solution, but failed. Could anyone give me some suggestions? Thanks a lot.
lefuliang is offline   Reply With Quote
Old   August 27, 2013, 19:33
Make sure you did not hit your max or min time step size. Widen the limits if necessary. Small time steps are essential for surface tension models.
Can you post a picture of your mesh?
Also, an inlet to produce the liquid might be better than a source term. Not sure of that, but worth a try.
Old   August 28, 2013, 00:13
Smile
LE Fuliang
Thanks a lot!
I posted meshing grids in enclosed fig.3a and fig.3b. Fig.3a is overview whereas fig.3b is partial enlarged view.
The initial timestep is 0.0001 s (same as min timestep), then it keeps increase until it touches max timestep 0.1s. I also used double precision as CFX manual suggests.
Old   August 28, 2013, 00:24
LE Fuliang
A meshing grid view in thickness direction is also attached in figure3c.
Old   August 28, 2013, 02:55
Some comments:
* Surface tension will not be very accurate with the sort of aspect ratioes you have here. I would check your mesh is OK before proceeding too far.
* If this simulation is 2D then only use a single element thickness. Even better, use a CFD model with a proper 2D model like Fluent. Fluent is much better than CFX for simulations with surface tension anyway.
Old   August 29, 2013, 05:37
LE Fuliang
Thanks a lot. Fluent result of 2D case seems much better.
Some comments:
Old   August 29, 2013, 06:49
Yes, if this can be done 2D you will do a lot better with Fluent.
free surface problem with capillary effect rabbitmelon CFX 25 August 16, 2013 04:05
CFX PROBLEM ???? or TECHPLOT mohammad CFX 0 September 3, 2012 22:51
VOF && surface tension -- PROBLEM bohis FLUENT 3 May 29, 2011 17:35
Surface of revolution problem in CFX Post Mankim CFX 3 January 5, 2010 06:38
Surface tension problem. Kes FLUENT 0 May 19, 2008 23:49
