August 26, 2013, 04:58 |
solution termination with roughness error
hi experts.
I'm simulating a weir containing a rough region in the middle of it. This rough wall band is surrounded by smooth wall. when I set the roughness to 8 mm after 23 iteration solver is terminated by this error: Parallel run: Received message from slave ----------------------------------------- Slave partition : 2 Slave routine : cUCOEF Master location : RCVBUF,MSGTAG=1032 Message label : 002100029 Message follows below - : +--------------------------------------------------------------------+ | ERROR #002100029 has occurred in subroutine cUCOEF. | | Message: | | The solver has detected a negative Uplus in the turbulent wall | | functions. The likely reason is a wall roughness which is too | | large. Please check that the wall roughness is correct. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. But when I set high values of roughness to the entire of weir there is no problem! how can I fix this problem. thanks in advance. |
August 26, 2013, 06:19 |
Rep Power: 144 |
Have a look at the boundary of the rough region. There is probably some weird flow going on there. You might need to do something at the edge to make the numerics nicer, maybe blend the roughness from rough to smooth rather than a sudden jump.
August 26, 2013, 16:15 |
thank you for your advice.
August 26, 2013, 16:46 |
Bruno
Rep Power: 21 |
Also, what is the height of your first element next to the wall? It should not be bigger then your wall roughness height.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 11:39 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
