August 23, 2013, 23:54 |
Problem with the convergence for CFX solve
Rep Power: 14 |
Hi.
I'm architect learning a bit about aerodynamic and Ansys. I want to simulate the wind along a street with a small barrier (wall) in the middle using CFX. So, following some tutorials and posts found here, I built a domain, the mesh, set up the boundary condition (wall no slip for ground, front plane and black plane, inlet, outlet, and opening for the sky) and ran a simulation with a good result. Here I have some screenshots of the mesh and results: http://imgur.com/a/2lEQn http://imgur.com/a/ZChY3 The problem is that I wanted to change the inlet wind (originally a normal velocity of 6m/s) for a parabolic wind velocity profile from the inlet face in the domain using these expressions: Dt= 2[m] Ue= 6[m s^-1] Vel= Ue*(y/Dt)^0.36 http://imgur.com/a/kMxzf But now the CFX solve doesn't have convergence. http://imgur.com/a/vJ1or Someone understand what should I change or improve? |
August 24, 2013, 15:50 |
Bruno
Rep Power: 21 |
You simulation is converging, it's just doing so in a slower rate. Let it run for a few hundred iterations (not just the 100 CFX uses as default).
You might also want to play with the timestep you're using. Set a physical timescale to a fraction of lenght_scale/velocity_scale, which for your case I suppose would be 0.1/3 to 1/3 s. |
August 25, 2013, 04:33 |
Rep Power: 14 |
Thanks for your response, brunoc.
I'll try your suggestions and will publish here the results. |
August 25, 2013, 20:59 |
Rep Power: 14 |
Hi, I followed the suggestions but the solver doesn't reach a convergence, yet.
http://imgur.com/a/zlVKX Originally, with a inlet wind of 6m/s (flat velocity profile) 50 iterations were enough to get a convergence. I only changed the speed wind parameter for a expression to get a parabolic wind velocity profile, but now I don't have convergence at all. Any other suggestions? |
August 25, 2013, 21:34 |
Bruno
Rep Power: 21 |
Have you also tried changing the timestep?
August 26, 2013, 00:49 |
Rep Power: 144 |
This FAQ gives a range of suggestions: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
August 26, 2013, 03:32 |
Rep Power: 14 |
brunoc, ghorrocks, thanks for you help. I fixed it the problem. It was my fault, because just now I'm learning Ansys. I had put the expression Vel in a wrong field in the Inlet's details.
Now, I have a good convergence, again. Thanks |
convergence problem in the turbomachinery problem. | u k jha | CFX | 1 | September 7, 2010 19:41 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Continuity eq convergence problem | carno | FLUENT | 4 | February 8, 2008 05:04 |
AirPak 2.06 solve problem | ABS | FLUENT | 0 | October 4, 2005 18:58 |
convergence problem | Trushar | Phoenics | 5 | August 28, 2002 00:40 |
