furnace design using CFX
Old   July 25, 2013, 10:30
Default furnace design using CFX
mactone hsieh
mactone is on a distinguished road
Dear all,
I try to design a batch furnace with a flat flame burner mounting on the roof.
The dimension of the furnace is to be determined.
The goal is to achieve 1500 degree Celsius on the floor while the vertical velocity near the floor is small.
Is it appropriate to use ANSYS CFX as a tool for DESIGNING a furnace from scratch?
Is there any combustion tutorial of CFX or fluent available?
Thank you
mactone is offline   Reply With Quote
Old   July 25, 2013, 22:04
CFX can do this. I am not sure CFX is the best way to design a furnace but you can do it that way if you wish.
There are combustion tutorials provided with CFX. But if all you want is the temeprature at the bottom you probably do not need a combustion model and heat sources will do fine.
design, furnace, parameter
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
[Other] CFX 11.0 / Ansys Workbench Design modeller - .geo file Hectux ANSYS Meshing & Geometry 1 April 7, 2009 06:04
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 12:59
CFX design modeler Merkur CFX 0 June 5, 2006 11:44
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
