Heat transfer in a horizontal rectangular duct |
July 21, 2013, 02:37 |
Rep Power: 17 |
I need to analyse the flow in a horizontal rectangular duct and heat transfer is involved in the problem.
But I'm not sure if I should activate the gravity (buoyancy) then, because activating gravity I think will turn the scenario into a vertical duct flow. I use a velocity inlet and pressure outlet (at atmospheric pressure) and turbulence is involved. Could some one please clarify about this
Best regards, Santhosh. |
July 21, 2013, 06:18 |
Rep Power: 144 |
You need gravity if any bouyancy effects occur, such as liquids at the bottom, gas at the top, or heavy particles sinking and light one rising.
You can define the gravity vector in any direction you like, so you can model a horizontal duct with bouyancy. |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 17, 2014 23:45 |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
ADI code for heat transfer from rectangular plate | ayushman | Main CFD Forum | 0 | December 12, 2007 15:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Heat transfer B.Cs.. | Puck | FLUENT | 12 | August 1, 2002 05:12 |
