help me to set suitable outlet boundary condition
Old   July 20, 2013, 05:06
Shashwat
shaswat is on a distinguished road
Originally Posted by ghorrocks View Post
That has to start with you - you say fluid goes through the porous wall all over. So what controls it? You need some function to drive it. A defined flux? Maybe a concentration gradient? Maybe a constant value? So "some function" is a vague reference to the wide variety of functions you can use to define this flow.
Thank you Dr
I got the simulation what I expected. Now the the simulation is running
Thank you for your kind advice and help
Thank you
shaswat is offline   Reply With Quote
Old   July 28, 2013, 11:28
Shashwat
Dear all
Please find the attached cross sectional view of artery.The artery length is 100mm
The outer part is porous domain. I introduced free slip between fluid and porous interface . I set fluid - porous interface by using GGI.when I run the simulation I saw momentum and mass -2 is not at all executed . please clarify
Thank you
Old   July 28, 2013, 20:43
What is momentum and mass -2? Is that fluid flow in the porous domain?
Old   July 28, 2013, 22:46
Shashwat
I think it is fluid flow in the porous domain
Old   July 29, 2013, 01:13
So it looks like it is not solving the fluid equations in the porous region. Can you post your CCL?
Old   July 29, 2013, 05:22
Shashwat
Dear Dr
Please find the attached my CCL .
I don't know what is the problem
I need to solve this as soon as possible . Please help me in this regards.
Thank you
Reagrds
Old   July 29, 2013, 09:04
Where do you get the time step size from? Did you actually do something to show that time step was required or did you just guess?
You have your artery wall set to solid morphology. You probably want this porous (I am not sure about that).
You have the mass momentum model as free slip on the interface. You will want this to be no slip.
Why have you set a max coeff loops of 3? And why a minimum of 1? Remove the min loops and make the max loops something like 10.
Do you need the expert parameter? Have you checked you need it?
I would simplify this model to get the components working. I would model the arterey only (fluid flow only, and the fluid is a newtonian fluid) to make sure the time step and boundaries are working. Then add the porous wall. When that works add the non-newtonian fluid model.
Old   July 29, 2013, 11:19
Shashwat
I just guess . I want to show how the shear stress and other parameters changes with respect to time
Yes . I want this as a solid morphology having a porous in nature.
Is it wrong to define solid here? if I remove, will my result vary or not?
I have seen many articles they are using free slip boundary at the interface
Ok I will do
This part I am not sure. your advice is highly needed.
Thank you
Old   July 29, 2013, 22:57
Time Step: Do not guess, invariably you will get it wrong. Use adaptive time stepping, with 3-5 coeff loops per iteration. Then the solver will find the correct time step size.
Free slip: sure, you can use free slip but is that what you want? Then you will not get any realistic flow profile in the artery.
Do not put expert parameters in unless you know you need them and you know what they are doing. They are not called expert parameters for nothing.
Old   August 1, 2013, 02:39
Shashwat
I am facing the same problem . One cycle completed but there is no fluid flow inside the porous domain.
I changed from transient to steady state analysis, still I did't get.
can I assume porous domain initialization with free slip.
Thank you
Old   August 1, 2013, 03:28
Slip or no slip should not matter on the porous interface. If you are getting no flow in the porous region you have a more fundamental problem with your simulation.
I note your permeability is 2e-18[m^2]. I am no expert in porous flows but this sounds pretty low. Wouldn't that pretty much stop flow in the porous region?
Old   August 1, 2013, 09:32
Shashwat
I am also thinking . I tried with permeability 1[m^2] . I could not get a flow in the porous domain.
Since I am using turbulent model in the main flow. when the flow enters into the porous region it would be laminar flow . How to handle this ?
Thank you
Old   August 1, 2013, 19:04
Rather than randomly trying permabilities, how about working out what the permability actually is?
Old   August 1, 2013, 19:27
Shashwat
IT is actually 2e-18[m^2]
Old   August 1, 2013, 21:42
OK - so with a permability so low, will you get any flow?
In post #27 I recommended you simplify the model to get the components working. Have you done this?
Old   August 2, 2013, 03:30
Shashwat
Yes Dr.
It works fine . When I add a porous layer the momentum and mass for porous region not at all showing any response.
I now changed to transient to steady flow . I set 200 iteration. I could not not see any flow in the porous region.
Now , I am thinking to initialize the porous domain with Cartesian velocity components . But Don't know how to implement with out knowing velocity . Any suggestion
Old   August 2, 2013, 09:25
I have already said my suggestion two times - so here it is for a third time. Have you simplified your model (ie just use a newtonian fluid, and a simple geometry) to test that the porous material works as expected for a simple case?
Old   August 3, 2013, 07:31
Shashwat
I tested with straight pipe . the wall I consider porous . I simulate with Newtonian flow . I see the same result when I use non Newtonian fluid. Inside the porous domain momentum and mass equation is not solving. I applied free slip boundary condition.
I have a question . at the domain interface is it necessary to introduce source terms
Thank you
Old   August 3, 2013, 09:48
No, you should not source terms to model what I understand you are trying to model.
As the porous model is not working on a simpler model I would concentrate on getting it working on the simple model before going back to the full model. I do not know why it is not working for you, but try these things:
1) Try the porous region as a subdomain of the fluid domain rather than a separate domain. This should not need a GGI so you will have to remove that.
2) Change the porosity model options, like loss velocity type, the expert parameter and any others which look interesting. No harm in trying everything.
Outlet boundary condition for wave flume with interFoam solver Arnoldinho OpenFOAM 9 July 10, 2018 06:15
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 04:23
Outlet boundary condition colen CFX 6 March 8, 2010 23:49
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 09:07
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
