free surface problem with capillary effect
Old   July 28, 2013, 08:39
I would not worry about it. I suspect it will disappear with tighter convergence. But as the interface is reconstructed every time step these minor wiggles should dissappear wuick enough.
A much more important issue is that you will never achieve grid convergence with simulations involving gas/liquid/solid interfaces and moving contact lines. It is impossible with a Navier Stokes solver like CFX (or Fluent, Star-CD or any of the others to my knowledge).
Old   August 5, 2013, 06:03
rabbitmelon is on a distinguished road
hello, Mr. Horrocks. I've tried to solve the simulation with fine mesh. The results seem to be better. The copper flows to the end of the gap, when the gap is small. But there is always a small distance between the opening boundary at the end of the gap and the copper. I think that may because i have set the volume fraction at the opening for copper to 0. What does the "zero gradient" option for volume fraction at opening boundary mean?
rabbitmelon is offline   Reply With Quote
Old   August 5, 2013, 07:47
Can you post an image of the small gap?
zero gradient means the boundary condition is a Neumann type.
Old   August 5, 2013, 10:25
in the attach is the image of the small gap between the end and the molten copper
Old   August 5, 2013, 19:27
Yes, I suspect that is due to your specification of VF=0 at the boundary. I would not worry about it, as long as it is far away from the area of interest it should not affect things.
Old   August 16, 2013, 04:05
Hi, Mr. Horrocks. I've try various settings for the simulation and found out the things below.
1)For the modells with smaller gap size, where the capillary effect is significant, when the aspect ratio of the elements inside the gap bigger than 1 ist, for example 2.5 (the longer side of the element is in the flow direction of the copper), the molten copper will flow in the gap and form a symmetrical meniscus. The residual is stable and there are no periodical peaks. But when i run it with modells with the element aspect ratio of 1, there are peaks. There is no symmetrical meniscus, the copper flows either a litte more along the upper or the lower side of the gap at different time during the simulation. Only when i restrict the max. time step to a small value, the amplitude of the peaks is smaller and the simulation can run untill the copper reach the end of the gap, otherwise a great peak appears at some time and the simulation could be terminated with error.
2)For the modells with bigger gap size. The capillary effect is not so significant. Due to the gravitation, the copper should flow along the lower side of the gap. But when i run it with modells with bigger aspect ratio inside the gap, it will flow along the upper side. When i change the aspect ratio to 1, the copper flows along the lower side. But the periodical peaks still exist. I think that there might be still something wrong with other settings, and i will try further.
Why the modell with better aspect ratio for the smaller gap is unstabler? Is'nt the aspect ratio of 1 the best aspect ratio?
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
Problem in free surface modeling of water-oil mixture scythe FLUENT 4 November 12, 2013 12:47
Can Flow-3D plot the free surface area in Iso-surface or colour variable? therockyy FLOW-3D 1 June 20, 2010 20:36
Free surface VOF (fluid render effect) franco STAR-CD 1 July 20, 2009 06:42
Free Surface Problem - Convergance Toby FLUENT 0 July 3, 2008 00:16
