Transient simulation : Static temperature and time averaged static temperature
Old   July 2, 2013, 20:39
Default Transient simulation : Static temperature and time averaged static temperature
saisanthoshm88 is on a distinguished road
I have a transient simulation where I monitored the volume averaged static temperature and the volume averaged mean (time averaged) static temperature
i.e.., for instance :
Monitor1 - volumeAve(Temperature)@fluiddomain
Monitor2 - volumeAve(Temperature.Trnavg)@fluiddomain
I observed that the plots of Monitor1 and Monitor2 do not exhibit the same trend.
i.e.., the monitor1 which is the temperature at each time step shows a steady trend with the time.
so I expected that the Monitor2 which is the time averaged temperature also to show the same trend.
Which is however not the case, monitor1 is steady and monitor2 increases in time from a very low value.
This is how I actually proceeded -
- Carried out 20 iterations in steady state just to initialize the transient simulation
- Initialized the transient run with the steady state solution (20 iterations)
- Ran the transient simulation with a time step size of 0.1 [s]
- Increased the time step size to 0.5 [s]
- The simulation was allowed to run continuously
( i.e.., there was never a reinitialization of any statistic)
- The quantity volumeAve(Temperature.Trnavg)@fluiddomain - Monitor2 was monitored right from
the timestep1
Could some one please explain these trends of the monitor points
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   July 3, 2013, 08:13
Do some simple hand calculations and you will work it out - Take the monitor 1 values for 1, 2, 3, .... , last time steps and calculate the trnavg - You will find it increases from zero and asymptotically approaches the steady value like you are seeing.
Old   July 3, 2013, 12:05
Glenn,
I understand time weighted averaging as follows -
i.e.., for instance if the time step size = 0.1 [s] and
if the volumeAve(Temperature)@fluid = 300 [K] after the first time step (=0.1 [s])
And volumeAve(Temperature)@fluid = 310 [K] after the second time step (= 0.2[s])
Then during the third time step, volumeAve(Temperature.Trnavg)@fluid = ((300*0.1) + (310*0.2))/(0.1+0.2)
Please correct me if I'm wrong
Best regards,
Santhosh.
Old   July 3, 2013, 20:08
The time step size for the second time step is still 0.1.
Old   July 4, 2013, 03:18
Glenn,
I got the point. Thank you very much for the clarification.
Best regards,
Santhosh.
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 09:33
Temperature field stops changing in transient simulation Jeffzda OpenFOAM Running, Solving & CFD 1 September 25, 2013 02:19
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
