July 1, 2013, 17:03 |
Variable values in CFX expressions
Rep Power: 18 |
In the following expression -
((T/273[K]))^(1.81)*(101330[Pa]/Pref )*2.305e-5[m^2 s^-1] What kind of averaging is applied in CFX (CFD Post) to the temperature(T), i.e.., is it mass averaged or volume averaged or any other averaging is applied. Could some one please explain this.
Best regards, Santhosh. |
July 1, 2013, 19:58 |
Rep Power: 144 |
Are you calculating this function on the nodal values or over some form of average over a mesh object?
July 2, 2013, 02:08 |
Rep Power: 18 |
Hi Glenn,
No I did not average it over any object, I'm evaluating it just the way it is I mean it is evaluated as itself and not by passing it as an argument to some averaging function
July 2, 2013, 08:54 |
Rep Power: 144 |
Then it is calculated directly on the nodal values with no averaging, and returns a value at each node. Or are you asking what is the basis of the nodal values of temperature?
July 2, 2013, 09:04 |
Rep Power: 18 |
Thanks for the clarification Glenn, No im not asking about the basis, like i know that the nodal values are just a part of the solution and your reply clarified my question.
Reference Values for Troughs @ variable Angle? | hornig | FLUENT | 1 | April 12, 2014 23:26 |
problem with cfx expressions | TallesC | CFX | 4 | April 22, 2013 22:38 |
Initial Values for Trasient simulation with CFX | shaban | CFX | 1 | April 30, 2010 07:25 |
How to monitor variable values of point at t=0 sec | yunhee | CFX | 3 | February 13, 2008 13:45 |
Variable export from CFX post | Ram | CFX | 2 | October 20, 2005 07:00 |
