July 18, 2013, 04:45 |
#21 | |||
Matthias Voß
Rep Power: 20 |
Did you try the under-relaxation? How is the density ratio fluid/struct.? Last edited by mvoss; July 18, 2013 at 08:38. |
July 26, 2013, 16:04 |
#22 |
Rep Power: 13 |
which material characteristics are you using for the wall?
August 28, 2014, 13:11 |
#23 |
Raj
Rep Power: 12 |
I am also working on the same topic but I am having problem in the initial stage of the analysis. I have the geometry but I am unable to go to Modeler to do the meshing of the wall of the blood vessel. 1. This is the geometry of my model. 2. Fluid Domain 3. Surface of the blood vessel 4. Modeling error in the workbench Can anyone help me solve this problem? |
August 29, 2014, 09:11 |
#24 |
Matthias Voß
Rep Power: 20 |
How did you mesh the wall area? You need to give some info about the error in the meshing, otherwise it´s hard to tell what the problem is.
August 29, 2014, 10:59 |
#25 |
Raj
Rep Power: 12 |
I am not able to start the meshing. The last image is showing the workbench view. I tried refreshing, updating the project but nothing worked. Neither wall not he flow domain is available for meshing.
August 29, 2014, 12:26 |
#26 |
Matthias Voß
Rep Power: 20 |
So you don´t see any geometry when entering the ANSYS meshing environment? Not sure, but this could be due to the very small features. You could scale it up in the Design Modeler and scale it down after meshing. Try smth. bigger, like 1000µm, to see if this is passed onto the meshing.
November 10, 2016, 09:04 |
finding pulse pressure and velocitu formula
#27 |
ramin
Rep Power: 10 |
hello omni89
I am working on blood vessel.I have a problem with finding formula of my pulse pressure outlet and pulse velocity inlet . can you tell me the pulse pressure formula that you worked on it or give me some advice . my boundry condition is not exact sin function. even I USE curve fitting but I was't successful. this is my boundry condition. can any body help me to finding formula of this boundru condition? |
June 2, 2019, 04:40 |
Help please
#28 |
Ahmad hummeid
Rep Power: 7 |
Hello everyone
I trying to add a new material to ansys 15 but its not working can anyone please send me the material of blood vessel as ansys form ? its really important for me |
ansys 14, cfx, expressions, fsi simulation |
Pulsatile blood flow | Duncan | FLUENT | 12 | October 26, 2016 10:23 |
negative mass flow at the outlet of vessel at the last timestep! | smn | CFX | 7 | October 28, 2014 13:47 |
Blood flow with FSI in Ansys 12 | Marten | ANSYS | 9 | April 14, 2012 17:33 |
How to set pulsatile flow in cfx? | bmdaortiz | CFX | 4 | September 8, 2009 23:48 |
pulsatile flow | bernard | Main CFD Forum | 1 | June 25, 1999 04:27 |
