June 24, 2013, 18:44 |
What this error message means?
Meimei Wang
Rep Power: 16 |
Details of error:-
---------------- Error detected by routine PEEKCS CDANAM = BCP72 /VARIABLES/ENTHSTAT_FL1 /BCTYPE CRESLT = NONE Current Directory : /FLOW/BOUNDCON/ZN21 +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255. No results file has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | /cluster/home03/mavt/linin/complete_filezilla/flow_turning_check_- | | 006: | | | | mon | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Indirect start method returned non-zero exit code | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | Indirect solver job failed | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | After waiting for 60 seconds, 1 solver manager process(es) appear | | not to have noticed that this run has ended. You may get errors | | removing some files if they are still open in the solver manager. | +--------------------------------------------------------------------+
Best regards, Meimei |
June 24, 2013, 21:03 |
Rep Power: 144 |
Looks like it cannot find static enthalpy on a boundary condition. Did you define the temperature of other flow conditions correctly on a boundary condition?
June 25, 2013, 06:08 |
Meimei Wang
Rep Power: 16 |
How did you see that?
June 25, 2013, 07:36 |
#4 | ||
Rep Power: 144 |
From there and a few educated guesses and you have it |
June 25, 2013, 13:57 |
Edmund Singer P.E.
Rep Power: 21 |
Did you get this error by changing the ccl via command line (either injection during run or prior to start)?
I have had this happen to me when I changed a boundary condition by that method. For example, I changed a wall to an opening using a ccl text file and I forgot to provide the temperature condition. It has also occured when I didnt get the formatting exactly right on that change. |
November 18, 2022, 09:46 |
error is because of lack of information in varibale name about the belonging phase
Sobhan
Rep Power: 5 |
I had somehow the similar problem. I defined some new variables from multiplication of ordinary variables. for example: "VelocityMultiplication Expr": fluid.Velocity u* fluid.Velocity v Then "VelocityMultiplication Var": defined via algebraic equation from the above expression I realized, by Using the new variable, I forgot to write the fluid phase name behind the variable. PhaseName.VariableName in above example, if you want to use, then use: fluid.VelocityMultiplication Var >> like ave(fluid.VelocityMultiplication Var)@Domain I got the above error, because I used only new Variable name without mentioning the phase belong to. |
What means "bounding epsilon"? | gara1988 | OpenFOAM Running, Solving & CFD | 3 | October 29, 2012 09:59 |
What does wrongOrientedFaces means? | ivan_cozza | OpenFOAM Running, Solving & CFD | 0 | January 20, 2011 06:25 |
what's couple in wall boundary conditions means? | eve | FLUENT | 1 | July 23, 2007 13:20 |
BC evaluation by means of external lists allocated in the solver | shrina | OpenFOAM Running, Solving & CFD | 2 | January 18, 2007 12:29 |
What means % in Fortran? | What means % in Fortran | Main CFD Forum | 2 | April 20, 2004 15:34 |
