June 18, 2013, 08:52 |
Post-process Isosurface Setting Anomalies
Manav Gunesh
Rep Power: 13 |
Dear All,
I ran a multiphase simulation in a closed domain discretizing a tunnel. I wanted to display the free surface of the primary fluid which is water during the run therefore resorted to isosurface in the post process results. My only concern with the latter is the fact that: * when i set the volume fraction of water to 0.5 as recommended i get patches of unfilled space in the domain. * when i do decrease the water volume fraction i get a better result as the flow covering of the domain. Your help is very much appreciated friends. If you could shed some light on the matter and kindly advise a better solution. Thanks, AeroJay |
June 19, 2013, 20:14 |
Rep Power: 144 |
Can you post images of what you are seeing? Also post the CCL file.
June 20, 2013, 03:44 |
Isosurface details
Manav Gunesh
Rep Power: 13 |
Dear Ghorrocks,
[I]Please find the comparative figures denoting the value of 0.05 and 0.5 for the post-processed displays. Also find the CCL file attached. Thanks, AeroJay CCL.txt Value 0.05.jpg Value 0.5.jpg |
September 5, 2013, 04:16 |
Daan de Boer
I have a similar problem with a sloshin study, there are gaps in iso-surface near the baffle plates. Hope someone knows a solution.
September 5, 2013, 06:17 |
hamed
Rep Power: 17 |
is that some kind of chute or spillway?did you calculate the water table in the slop by open channel hydraulic equations? did you use a proper mesh grid on the slop which could express the water table ?it can be concluded by the pic you attached that there is no value for water volume fraction=0.5 and on the slop there is a very thin layer of water caused by high frude number.. i think a higher mesh quality would help.pleas let me know if it solves the problem i am working on some kind of similar model
September 5, 2013, 09:13 |
Rep Power: 144 |
I think Hamed is on the right track - a finer mesh will probably resolve this.
isosurface, multiphase, volume fraction |
contours display in post process | askriitr | FLUENT | 0 | July 1, 2009 11:55 |
cfx post process help | musman | CFX | 3 | May 19, 2009 06:01 |
post process to get an arbitrary face data | oniboy | Siemens | 2 | February 28, 2008 23:12 |
how to post process with visual3 | dell | Siemens | 2 | December 17, 2002 02:59 |
200 data files to post process (how?) | Mark R | FLUENT | 1 | August 9, 2001 14:35 |
