June 18, 2013, 08:40 |
Loading mesh from ICEM with multizone
behne
Rep Power: 15 |
Hi all,
I'm doing a fluid structure interaction with Ansys WB 14.5. I want to use a ready meshed ICEM mesh. So i load it with the multizone option. I just change the blocking (i don't change the Geometry!) in icem, convert it to unstr. and close icem. Back to mechanical it cant create a mesh. the message is: MultiZone could not generate a valid mesh. Anybody can help me? |
June 24, 2013, 04:56 |
#2 | |
Matthias Voß
Rep Power: 20 |
June 27, 2013, 07:04 |
behne
Rep Power: 15 |
I loaded a total new Blocking and renamed the part name of the new blockingmaterial to the old one, wich i replaced.
June 27, 2013, 07:22 |
Matthias Voß
Rep Power: 20 |
let me guess... you changed from multizone to hex-blocking?
i would highly recommend to use the standalone icem container instead of iceminteractive from within meshing. btw: what´s your application since i am also into FSI. |
June 27, 2013, 11:42 |
behne
Rep Power: 15 |
I think the problem is that workbench cant read the mesh and fix it to geometry. I follow all the rules for interactive Editing.
Yes im doing hex-blocking in ICEM... I would prefer using only ICEM, but how can i get the mesh into workbench?? My Simulation is a transintent fluid signal witch interact with the a plate. |
fsi, icem mesh, multizone |
Error loading ICEM mesh into Fluent | mix | FLUENT | 3 | July 5, 2015 21:23 |
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? | jash | ANSYS Meshing & Geometry | 19 | July 23, 2013 19:48 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 10:14 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 06:10 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
