June 7, 2013, 15:37 |
Working bench result files saving
Meimei Wang
Rep Power: 16 |
I'm using workbench CFX parameter set - Table of Design points to do the simulations. But the result files for different inputs are not saved after running. Usually after I run a table by 2 days. If I find out i need to have one more expression parameters as output, i have to run all the simulations again. That is not convenient and time wasting. How to save all the results file?
Best regards, Meimei Last edited by Anna Tian; June 8, 2013 at 15:05. |
June 9, 2013, 03:40 |
hamed
Rep Power: 17 |
you have to check the export check box at the most right position of the parameter tables before updating design points.
June 10, 2013, 04:25 |
Matthias Voß
Rep Power: 20 |
and YES.. if you need to add an new expression in e.g cfx-Post .. you need to rerun every DP in the table... which is very inefficient. Try to write a script which loops over your exported res.-files and pull out the expression via the script... saves you the extra runs but you have the numbers in that table externally but this is way better than to rerun all DP.
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 10:46 |
Windows Installation Petrbs Port Redux Patches and Binary Distribution | brooksmoses | OpenFOAM Installation | 0 | February 10, 2006 17:35 |
Working with compressed case and data files | Darrell Anthony Egarr | FLUENT | 0 | December 15, 2002 07:05 |
[making animations] fclose fails to close files? | Mika | FLUENT | 0 | March 30, 2001 08:19 |
