Suggestion on new dynamic viscosity expression in CFX |
June 13, 2018, 02:32 |
#21 |
Dr Gurubasavaraju
Rep Power: 11 |
I am trying to implement HB model (Discussed in this thread) in transient analysis. Below is the CEL code I used. But I am getting an error (see attachment) any specific reason for this error. CEL: &replace EXPRESSIONS: Bounded = min(max(Shear Strain Rate,MinValue[s^-1]),MaxValue[s^-1]) HB = ((1-exp(nu0*Bounded/tau0))*((tau0/Bounded)+K*Bounded^(n-1))) K = 2 [Pa s^0.3] MaxValue = 1.0e+10 MinValue = 1.0e-10 n = 0.3 nu0 = 0.6 [Pa s] tau0 = 4000 [kg m^-1 s^-2] END END END |
June 13, 2018, 02:50 |
#22 |
Titus Ofei
Rep Power: 13 |
Hi, floating error could be due to anything including poor meshing as well transient solution setup.
Again looking at your values, nu0 is too small and tau0 is too large. I think you have interchanged these values. Have a second look. |
June 13, 2018, 04:07 |
#23 |
Lance
Rep Power: 22 |
June 13, 2018, 04:31 |
#24 |
Gert-Jan
Rep Power: 28 |
I don't think it has anything to do with poor meshing ot transient solution setup, since your message already appears in the initialisation (see error messaage).
So, I think Titus is correct that something is wrong with your expression. Did you evaluate the expressions in Pre, using the plotting function? Alternatively, perform a first run with mild (small range) settings to get a reasonable initial guess and then your final case with the first run as initial guess. |
June 14, 2018, 00:36 |
#25 |
Dr Gurubasavaraju
Rep Power: 11 |
Thank you, It was an issue with the values....
June 14, 2018, 00:37 |
#26 | |
Dr Gurubasavaraju
Rep Power: 11 |
solid particle dynamic viscosity | trinitron | CFX | 0 | August 2, 2012 03:45 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
dynamic viscosity setup | fat bug | CFX | 5 | March 20, 2008 11:01 |
Does CFX support LES, local dynamic mdoel | JJ | CFX | 0 | August 28, 2003 21:15 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
