animation CFX
Old   May 25, 2013, 03:06
Default animation CFX
mat_cfd is on a distinguished road
I am trying keyframe animation in CFX for the first time. I am following the procedure as given in tutorial but its not working out for me. I am not able to see any frame between two keyframe. My keyframe 1 and 2 are cutting the entire domain but are not concentric.
I tried tutorial Static Mixer . Animation is working fine as in tutorial but if I rotate view of one keyframe result is same with no frame visible between two keyframe while playing animation. CFX post guide do not say that keyframe centre has to be on same axis. Any help to make the animation work?
Thanks
mat_cfd is offline   Reply With Quote
Old   May 26, 2013, 22:47
Mal
Ma.L
Mal is on a distinguished road
try to use the Keyframe Animation instead of Quick Animantion.
in the TimeSelector choose the #1,and the creat News1 in Keyframe Animation.input a number in the #of Frames window.the number should be close to the last number.
then, in the TimeSelector choose the #(last one),and creat News2 in Keyframe Animation.keep the default number.
retun to the #1 and begin your animation.
i have tried this method.
good luck to you.
Mal is offline   Reply With Quote
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Different flow pattern between OpenFOAM and CFX AirS OpenFOAM 0 January 12, 2010 08:08
heat generation in CFX Ema CFX 4 August 7, 2009 06:39
Electronics Enclosure Analysis with CFX Simulation Engineer CFX 1 April 22, 2009 12:08
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 12:59
