May 23, 2013, 11:01 |
Re-Mesh boundary "contraction"
Robert
Rep Power: 13 |
Hallo,
i have a problem and hope you can help me. I have an assembly consisting of 2 cylinders and 1 pipe, which connects both. When the pistons are in motion, they move the fluid from 1 cylinder to the other and back. In picture 1 u can see the mesh and picture 2 the state after the Re-Mesh-process. My problem is, that i don't know which Mesh Motion option i should use. The current ones are "Specified Displacement" for piston (no. 1) in picture 1, "Unspecified" for the cylinder walls (no. 2) and "Stationary" for no. 3. At "Part Map" in the Remeshing options i entered the boundaries with the numbers 1 and 2. For the pistons (1) it works, because the boundary moves. For the cylinder walls it isn't functioning, because the walls arent getting "contracted". How can i solve this problem? Thanks in advance for any help. |
June 3, 2013, 05:08 |
Robert
Rep Power: 13 |
Hi again,
this note "only translational mesh motion is automatically handled by the ICEM CFD Replay remeshing option" from the CFX Reference Guide, explains, why it isn't functioning. My solution now is, that manage the contraction of the sidewalls is managed in my Replay file. The steps are: 1 Get the current simulation values with the program cfx5mondata.exe 2 close the old .tin file and create a new one with the current values 3 Remesh this new geometry I have attached a file with the steps, to get these values, as it took some time to get it working. Regards Robert |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
