Centrifugal compressor modeling by real gas
Old   May 7, 2013, 04:35
Default Centrifugal compressor modeling by real gas
omid
omidiut is on a distinguished road
Hi all
I'm trying to simulate a 5 stage centrifugal compressor. i simulate it by Ideal flow mixture and have not any error. i try to simulate it by real gas fix component mixture. the mixture components are: C2H6 - C3H8- C4H12
C3H8 has maximum mass fraction about 0.98.
i use several equation of state ping-robinson, redKw, but i can't give any accurate result, for example the pressure ratio of compressor be 50 !!
for most investigation i try to simulate only one impeller but this errors occurs.
Now what is the reason of this big difference ? Is there any consideration for simulation of real gas flows?
Best regards.
omidiut is offline   Reply With Quote
Old   May 7, 2013, 20:23
The more complex material model is much harder to converge - this is pretty obvious. So you will need to use smaller timesteps and possible double precision to get it to converge. Also mesh quality is very important - the better the quality the easier it will be.
Old   May 8, 2013, 04:19
omid
Thank you Dear Ghorrocks for your reply
Is there any expert parameter setting to improve convergence procedure?
it seems to be real gas has very expensive computational lost.
at the first iteration there is notice about high mach number about 80.1, and then overflow error.. its only occurs when real gas modeled. have you any suggestion?
best regards.
Old   May 8, 2013, 04:22
No..... If there was, don't you think it would be set by default anyway?
Read the section on obtaining convergence - Small time steps, double precision, a good initial condition, high quality mesh.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
view factor yoollooz Fluent UDF and Scheme Programming 0 March 1, 2013 01:44
error message cuteapathy CFX 14 March 20, 2012 07:45
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
