April 15, 2013, 15:38 |
Inlet boundary conditions from profile data
Mark
Rep Power: 13 |
Dear All
I have applied an inlet boundary condition from a previous simulations outlet using profile data and it looks great for the first 20mm or so however.... just after that a section of essentially stationary fluid develops for about 300mm right against the wall like a very shallow bump. This doesn't exist in the full size flow so it is developing due to the implementation of the profile data inlet condition. Has anyone else come across this? Is there any way to eliminate it? I have tried manipulating the data a bit to see if it is an issue with the velocity data but it appears not. Many thanks Mark |
April 15, 2013, 20:09 |
Rep Power: 144 |
Please post an image. But as you describe it is probably the flow developing from your inlet condition to a flow more suited to the geometry, and that transition involves a separation.
April 29, 2013, 10:17 |
Mark
Rep Power: 13 |
Hi
It turned out there was an adverse pressure gradient that the velocity inlet was not accounting for. I tried using a total pressure and direction inlet with far more positive results, thank you for your input it hadn't occurred to me that the outlet would only sample the selected variable. By drawing a line at the point i was reducing the domain too in tandem with a total pressure and direction option the feature is far less dominant. Many thanks once again Mark |
Inlet Boundary conditions for pressure driven flow in DSMC | Jesgonse | OpenFOAM Programming & Development | 5 | October 3, 2014 10:52 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 09:39 |
inlet boundary conditions | newOFuser | OpenFOAM | 1 | January 10, 2013 09:08 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
NON-UNIFORM VELOCITY INLET BOUNDARY PROFILE | MURAT | Main CFD Forum | 0 | December 30, 2003 22:08 |
