starting Transient analysis from the previous time step.
Old   March 27, 2013, 03:30
Default starting Transient analysis from the previous time step.
Govindaraju
kmgraju is on a distinguished road
Dear all
I have completed transient analysis for 2 sec. I feel that the solution is not converged so, I want to increase to another 2 or 3 s. Is it possible to do the analysis from the previous time step? If so kindly help me how to so the setup in the solver.I need your opinion .
Thank you
kmgraju is offline   Reply With Quote
Old   March 27, 2013, 04:03
Lance
Lance is on a distinguished road
In the solver:
initial values specification/file name: specify your last .res or full .trn file
check "continue history from"
Lance is offline   Reply With Quote
Old   March 27, 2013, 14:55
Thiagu
jthiakz is on a distinguished road
Step1: Open the final result in CFX pre and check the initial time setting, If it is automatic no probs other wise change it to automatic and write def file
Step 2: In solver manger locate the the new def file and check the initialization and also enable continue run from history" , now you check and update us...
jthiakz is offline   Reply With Quote
Old   April 3, 2013, 14:11
Govindaraju
I have completed transient analysis first 2 s then 1 s then 1 s . but I could not able to load all the results. I found only the last time step results.how can i load all the results.
Thank you
Old   April 3, 2013, 23:01
Phil
cycleodyssey is on a distinguished road
Hiya,
CFXPre defaults to keeping the last time step only usually, this reduces file size as if you save for every step soon transient runs take up a lot of space...
To save steps you need to run again but change the setup in CFXPre. In CFXPre click on output control --> Trn Results which gives you options for output frequency for every time step, or intervals etc. Run simulation again and it will save trn results for the output frequency selected. If you want to save residuals you need to select them in CFXPre at Output Control -> Results -> select Output Equation Residuals text box.
Another way is to monitor points of interest, like Cl or Cd or whatever you are interested in, then you can export this in solver by right clicking on solver window --> export to csv. Residuals are included here as well...
Cheers
cycleodyssey is offline   Reply With Quote
Old   April 4, 2013, 01:45
Govindaraju
Originally Posted by cycleodyssey View Post
Hiya,
Cheers
Thank you
so much
I have another question to clarify. I use total time 4s. each cycle ends in 1 s
I have given each time step of 0.005s ( total time step 800) . But my question is , to write the transient results from 3rd cycle on words provided the solver has to run for 1st and second cycles normally. But the transient results should write from 3rd cycle . Please help me how it is possible.
If I skip the cycles will the solution accuracy affected?
Is there any way to reduce the solution time for the same time steps (400 time steps) and it is for 3rd cycle and 4th cycles ?
Thank you
Time step size and max iterations per time step pUl| FLUENT 31 October 23, 2020 23:50
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Time step in transient simulation shib FLUENT 0 June 17, 2010 14:07
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
