Question about outlet boundary condtion settting for transitional model
Old   March 3, 2013, 14:45
Question Question about outlet boundary condtion settting for transitional model
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
When I use the transitional model (Gamma Theta Model), I need to set up the turbulence intensity at the outlet boundary conditions. I'm confused about how do I know it before I simulate it?
Thanks!
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   March 3, 2013, 17:55
You do not specify the turb intensity at outlets. Obviously the turbulence just exits the domain and plays no role in the simulation. Why do you want to specify the turbulence at the outlet?
If you change the outlet to an opening, this will allow back flow and then you will need to specify the conditions of the back flow fluid including turbulence intensity.
Old   March 3, 2013, 19:35
Smile
Anna Tian's Avatar
Meimei Wang
Thank you very much! Yes. I set it as opening.
Best regards,
Meimei
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 18:15
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
Question about the outlet boundary condition. G.H.Lee Main CFD Forum 5 April 29, 1999 05:50
