February 25, 2013, 13:07 |
Axial Flow Pump Performance Prediction
Bharath
Hi All,
My Name is Bharath, I am Working in CFD Team last month i got one project on Axial Flow pump performance prediction. I carried out the analysis in Pumplinx Simerics ,Autodesk CF Design and Solid Works Flow Simulation. All 3 Analysis Software are giving nearly same result with 1 or 2 % difference. Actually customer shared the previous tested result of same pump and we compared the Analysis result with the tested result .The Head and Flow rate is matching nearly to the tested result but efficiency is not matching. almost 50% effieciency is less compared to tested result example 78% tested result but in Analysis it is coming 36 to 40%. please help me to find the reason why it is not matching with the tested result. Following Boundary Conditions i Had tried 1.Inlet - Atmospheric Pressure, Outlet tested Result Total Pressure 2.Inlet - Atmospheric Pressure, Outlet Tested result Flow Rate If you have any sugesstion on this please write to my mail ID - nbharath1988@gmail.com Thanks in Advance, Bharath |
February 25, 2013, 17:51 |
Rep Power: 144 |
There are many textbooks written about CFD accuracy. This FAQ is a start: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Pump characteristic / performance curve | husker | STAR-CCM+ | 4 | February 20, 2012 03:46 |
Asking simulation axial flow fan... | teguhtf | FLUENT | 10 | January 4, 2012 14:38 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
axial flow pump, inflow boundary | tma | CFX | 3 | September 26, 2002 15:28 |
