CEL simple error
Old   February 22, 2013, 01:51
Exclamation CEL simple error
Naishadh
naishadh is on a distinguished road
ERROR
Syntax error detected in the expression assigned to 'CP'.
Successfully read 22 characters:
RefPressure == 10 [Pa]
then error detected at:
Dynhead=0.5 * areaAve(Density)@inlet * areaAve(Velocity)@inlet^2
cp=(Pressure-RefPressure)/Dynhead
Details - Syntax error: variable name may not follow units specifier.
I have tried using units for density and velocity but its not working....!!
Can anyone help me out with proper way to assign units.. ?
I am naive in CFX and CEL sooo...!!!
Thank you.
naishadh is offline   Reply With Quote
Old   February 22, 2013, 03:33
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Change to
RefPressure = 10 [Pa]
and
(areaAve(Velocity)@inlet)^2
Should do it? I think =/
jrunsten is offline   Reply With Quote
Old   February 22, 2013, 03:45
Naishadh
Thank you Jrunsten for your reply...
I did try that and if I use '=' its showing me...
ERROR
Successfully read 12 characters:
RefPressure
= 10 [Pa]Dynhead=0.5 * areaAve(Density)@inlet * (areaAve(Velocity)@inlet)^2
Details - Unexpected character.
and I used same syntax as u mentioned and still it shows..
ERROR
its first time I am using CEL...
Is there any other basic things i need to assign before I write my expression ?
Thank you...!!
cel expression, cfx error, cfx simple error
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
