February 19, 2013, 02:03 |
Why i am getting this error?
Arthur Loginow
Rep Power: 14 |
I did the geometry using solidworks, then made the mesh at workbench and as soon as i load cfx the geometry looks like this (See the picture), No idea of whats wrong in here, as you can see the geometry looks nasty.
February 19, 2013, 05:02 |
Rep Power: 144 |
If you mean those lines on it - they are because those mesh edges trigger the corner critereon as the element angle is high. This is a common problem when you have a coarse mesh.
So the solution is to use a finer mesh. There is no way you would ever get an accurate simulation on a mesh that coarse. |
February 19, 2013, 21:35 |
Arthur Loginow
Rep Power: 14 |
Thank you sir i will try that.
February 19, 2013, 21:54 |
Arthur Loginow
Rep Power: 14 |
Ok, that problem was fixed thanks to your advice ghorrock, but now i have a different error, why my geometry looks like this? It looks irregular and i really have no idea why
February 19, 2013, 22:13 |
Rep Power: 144 |
Again, it is your mesh. The mesh is representing your shape with flat triangles, so it will depart from the real geometry. The finer the mesh the smaller the deviation.
But again, if you can see the deviation easily then you mesh is too coarse. A realistic mesh will have this deviation small enough that you have to zoom right in to see it. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 18:43 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 16:46 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 11:58 |
