February 16, 2013, 09:30 |
Ansys CFX exited with return code 1.
Hello everyone,
I am doing fluid structure interaction using Ansys transient structural and CFX.The solver was started running smoothly.while running it was getting crashed.Then later I restarted.Then it shows the above error(Ansys CFX exited with return code 1.).But it is also showing that no isolated fluid regions were found. |
May 5, 2014, 04:52 |
sree
Rep Power: 12 |
hi,,
i am also getting a same error message...is to due to lack of proper boundary conditions or due large timesteps?? have you found the answer?? |
May 5, 2014, 06:51 |
Rep Power: 143 |
CFX has lots of unhelpful error messages and this is a good example.
It probably means the simulation diverged. Can you post the output file? And an image of what you are modelling. |
May 6, 2014, 04:44 |
sree
Rep Power: 12 |
hi glen,
thanks for your prompt reply.. Problem definition: a flexible plate which is immersed in a fluid flow,placed horizontally and fixed at four sides(square faces in figure). I have coupled the systems using transient structural and cfx.The domain is created by aplying "boolean" to the fluid region. But when i try to run the solver,it says "No isolated fluid regions found"...!! Is it because of any error in the interface definitions??? How do you define your interface??? is it because of using boolean option..?? The figures of my domain are attached here.. please help.. |
May 6, 2014, 04:57 |
sree
Rep Power: 12 |
hi glen,
this is the outfile i obtained.. This run of the CFX-14.0 Solver started at 14:21:43 on 06 May 2014 by user user on USER-PC (intel_xeon64.sse2_winnt) using the command: "F:\softwares\ANSYS Inc\v140\CFX\bin\perllib\cfx5solve.pl" -batch -ccl runInput.ccl -fullname "Fluid Flow CFX_003" Setting up CFX Solver run ... +--------------------------------------------------------------------+ | | | Processing ANSYS Input File (Running CCL2MF) | | | +--------------------------------------------------------------------+ Created E:\M.Tech\MY Project\project files\miller exp 2_pending_tasks\dp0_CFX_Solution_1\Fluid Flow CFX_003.ansys\ANSYS.mf +--------------------------------------------------------------------+ | | | Starting ANSYS Solver | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | CFX Command Language for Run | | | +--------------------------------------------------------------------+ LIBRARY: MATERIAL: Water Material Description = Water (liquid) Material Group = Water Data, Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 997.0 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4181.7 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 2.57E-04 [K^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: ANSYS Input File = data_transfer_only_ds.dat Option = ANSYS MultiField COUPLING TIME CONTROL: COUPLING INITIAL TIME: Option = Automatic END COUPLING TIME DURATION: Option = Total Time Total Time = 5 [s] END COUPLING TIME STEPS: Option = Timesteps Timesteps = 0.1 [s] END END END INITIAL TIME: Option = Coupling Initial Time END TIME DURATION: Option = Coupling Time Duration END TIME STEPS: Option = Coupling Timesteps END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Fluid Location = B129 BOUNDARY: Default Domain Default Boundary Type = WALL Location = \ F130.129,F131.129,F136.129,F137.129,F138.129,F140. 129,F141.129,F143.1\ 29,F144.129,F145.129,F146.129,F147.129,F148.129,F1 49.129 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END MESH MOTION: Option = Stationary END END END BOUNDARY: inlet Boundary Type = INLET Location = inlet BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Normal Speed = 5 [m s^-1] Option = Normal Speed END MESH MOTION: Option = Stationary END END END BOUNDARY: interface Boundary Type = WALL Location = interface BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END MESH MOTION: ANSYS Interface = FSIN_1 Option = ANSYS MultiField Receive from ANSYS = Total Mesh Displacement Send to ANSYS = Total Force END END END BOUNDARY: outlet Boundary Type = OUTLET Location = outlet BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Average Static Pressure Pressure Profile Blend = 0.05 Relative Pressure = 0 [Pa] END MESH MOTION: Option = Stationary END PRESSURE AVERAGING: Option = Average Over Whole Outlet END END END BOUNDARY: sym1 Boundary Type = SYMMETRY Location = sym1 BOUNDARY CONDITIONS: MESH MOTION: Option = Unspecified END END END BOUNDARY: sym2 Boundary Type = SYMMETRY Location = sym2 BOUNDARY CONDITIONS: MESH MOTION: Option = Unspecified END END END DOMAIN MODELS: BUOYANCY MODEL: Option = Non Buoyant END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = Regions of Motion Specified MESH MOTION MODEL: Option = Displacement Diffusion MESH STIFFNESS: Option = Increase near Small Volumes Stiffness Model Exponent = 10 END END END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Fluid 1 Material = Water Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END HEAT TRANSFER MODEL: Option = None END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = Laminar END END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [Pa] END END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Include Mesh = No Option = Selected Variables Output Variables List = Pressure,Total Mesh Displacement,Velocity OUTPUT FREQUENCY: Option = Every Coupling Step END END END SOLVER CONTROL: ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 3 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END EXTERNAL SOLVER COUPLING CONTROL: COUPLING DATA TRANSFER CONTROL: Convergence Target = 1e-2 Under Relaxation Factor = 0.75 ANSYS VARIABLE: FZ Convergence Target = 1 END ANSYS VARIABLE: UZ Convergence Target = 1 END END COUPLING STEP CONTROL: Maximum Number of Coupling Iterations = 10 Minimum Number of Coupling Iterations = 1 SOLUTION SEQUENCE CONTROL: Solve ANSYS Fields = Before CFX Fields END END END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 14.0 Results Version = 14.0 END SIMULATION CONTROL: EXECUTION CONTROL: EXECUTABLE SELECTION: Double Precision = Off END INTERPOLATOR STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END END MFX RUN CONTROL: MFX RUN DEFINITION: MFX Run Mode = Start ANSYS and CFX Process ANSYS Input File = On Restart ANSYS Run = Off END MFX SOLVER CONTROL: ANSYS Installation Root = F:\softwares\ANSYS Inc\v140\ansys END END PARALLEL HOST LIBRARY: HOST DEFINITION: userpc Remote Host Name = USER-PC Host Architecture String = winnt-amd64 Installation Root = F:\softwares\ANSYS Inc\v%v\CFX END END PARTITIONER STEP CONTROL: Multidomain Option = Independent Partitioning Runtime Priority = Standard EXECUTABLE SELECTION: Use Large Problem Partitioner = Off END MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARTITIONING TYPE: MeTiS Type = k-way Option = MeTiS Partition Size Rule = Automatic END END RUN DEFINITION: Run Mode = Full Solver Input File = Fluid Flow CFX.def END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Memory Allocation Factor = 1.0 END PARALLEL ENVIRONMENT: Number of Processes = 1 Start Method = Serial END PROCESS COUPLING: Process Name = CFX Host Port = 49503 Host Name = USER-PC END END END END |
sree
Rep Power: 12 |
| | | Solver | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | | | ANSYS(R) CFX(R) Solver 14.0 | | | | Version 2011.10.10-23.01 Tue Oct 11 00:28:38 GMTDT 2011 | | | | Executable Attributes | | | | single-int32-64bit-novc8-noifort-novc6-optimised-supfort-noprof-nos| | | | (C) 2011 ANSYS, Inc. | | | | All rights reserved. Unauthorized use, distribution or duplication | | is prohibited. This product is subject to U.S. laws governing | | export and re-export. For full Legal Notice, see documentation. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Job Information | +--------------------------------------------------------------------+ Run mode: serial run Host computer: USER-PC (PID:2464) Job started: Tue May 06 14:22:01 2014 Connecting to the following master process: Host Name : USER-PC Port Number : 49503 License Cap: ANSYS CFX Solver (Max 128K Nodes) License Cap: ANSYS CFX Solver (Introductory) License ID: USER-PC-SYSTEM-1800-007029 +--------------------------------------------------------------------+ | Memory Allocated for Run (Actual usage may be less) | +--------------------------------------------------------------------+ Data Type Kwords Words/Node Words/Elem Kbytes Bytes/Node Real 21218.6 606.49 114.91 82885.3 2425.96 Integer 6563.2 187.60 35.54 25637.6 750.38 Character 3647.4 104.25 19.75 3561.9 104.25 Logical 80.0 2.29 0.43 312.5 9.15 Double 608.0 17.38 3.29 4750.0 139.03 +--------------------------------------------------------------------+ | Mesh Statistics | +--------------------------------------------------------------------+ | Domain Name | Orthog. Angle | Exp. Factor | Aspect Ratio | +----------------------+---------------+--------------+--------------+ | | Minimum [deg] | Maximum | Maximum | +----------------------+---------------+--------------+--------------+ | Default Domain | 7.6 ! | 21006 ! | 101 ok | +----------------------+---------------+--------------+--------------+ | | %! %ok %OK | %! %ok %OK | %! %ok %OK | +----------------------+---------------+--------------+--------------+ | Default Domain | 2 21 77 | 14 30 56 | 0 <1 100 | +----------------------+---------------+--------------+--------------+ Domain Name : Default Domain Total Number of Nodes = 34986 Total Number of Elements = 184660 Total Number of Tetrahedrons = 184660 Total Number of Faces = 14086 +--------------------------------------------------------------------+ | Initial Conditions Supplied by Fields in the Input Files | +--------------------------------------------------------------------+ Domain Name : Default Domain Mesh Coordinates +--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : Default Domain Global Length = 1.8106E-01 Minimum Extent = 6.0000E-02 Maximum Extent = 1.2500E+00 Density = 9.9700E+02 Dynamic Viscosity = 8.8990E-04 Velocity = 0.0000E+00 +--------------------------------------------------------------------+ | Boundary Condition Data Supplied by External Solver Coupling | +--------------------------------------------------------------------+ ANSYS Multi-field Solver : ANSYS CFX Boundary : interface CFX Variable : Total Mesh Displacement ANSYS Interface : 1 ANSYS Variable : DISP +--------------------------------------------------------------------+ | Checking for Isolated Fluid Regions | +--------------------------------------------------------------------+ No isolated fluid regions were found. +--------------------------------------------------------------------+ | The Equations Solved in This Calculation | +--------------------------------------------------------------------+ Subsystem : Mesh Displacement X-Disp Y-Disp Z-Disp Subsystem : Momentum and Mass U-Mom V-Mom W-Mom P-Mass CFD Solver started: Tue May 06 14:22:32 2014 +--------------------------------------------------------------------+ | Convergence History | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing transient file 0_CS.trn | | Name : Transient Results 1 | | Type : Selected Variables | | Option : Every Coupling Step | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | CFX encountered the error: Read. Fatal error occurred when reque- | | sting Total Mesh Displacement for interface. | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | cplg_SendCommand failed to send the command: ERROR -- CFX encount- | | ered the error: Read. Fatal error occurred when requesting Total | | Mesh Displacement for interface. | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine cplg_SendCommand | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following transient and backup files written by the ANSYS CFX | | solver have been saved in the directory E:/M.Tech/MY | | Project/project files/miller exp | | 2_pending_tasks/dp0_CFX_Solution_1/Fluid Flow CFX_003: | | | | 0_CS.trn | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | ANSYS Solver terminated with return code 256 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The results from this run of the ANSYS solver have been written to | | E:\M.Tech\MY Project\project files\miller exp | | 2_pending_tasks\dp0_CFX_Solution_1\Fluid Flow CFX_003.ansys | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | Warning! | | | | The ANSYS CFX Solver has written a crash recovery file. This file | | has been saved as E:/M.Tech/MY Project/project files/miller exp | | 2_pending_tasks/dp0_CFX_Solution_1/Fluid Flow CFX_003.res.err and | | may be an aid to diagnosing the problem or restarting the run. | | More details should be available in the solver output section of | | the output file. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | E:/M.Tech/MY Project/project files/miller exp | | 2_pending_tasks/dp0_CFX_Solution_1/Fluid Flow CFX_003: | | | | mon | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
May 6, 2014, 21:04 |
Rep Power: 143 |
The real error is "Fatal error occurred when requesting Total Mesh Displacement for interface." Sounds like a problem coupling CFX to ANSYS. Make sure the FSI run is set up correctly.
May 7, 2014, 04:47 |
sree
Rep Power: 12 |
hi glen,
thanks for your suggestion. I think it is the problem with the interface..The interface i have chosen includes the two large horizontal faces of the plate,in the structural region and the similar faces in the cavity formed in fluid region, as interface in the cfx.. Is this definition correct???..Does more faces needed to be added for interface..?? Is it necesssary that all the faces immersed in the fluid region needs to be considered as interface..?? |
May 7, 2014, 07:21 |
#9 |
Rep Power: 143 |
Have you looked at the FSI tutorial examples? That shows you how to set up FSI cases.
The ANSYS CFX solver exited with return code 1 | kola77 | CFX | 24 | April 11, 2022 07:32 |
ANSYS CFX solver exited with return code 2 | vmlxb6 | CFX | 6 | June 22, 2017 18:01 |
how to map resultd from cfx to ansys? | ritesh | CFX | 2 | June 1, 2011 07:52 |
Data Read Error ansys CFX | fcabrales | CFX | 3 | April 18, 2011 18:21 |
Return Code 2 - CFX 11.0 AMD 64 | Bayard Morales | CFX | 0 | December 5, 2007 08:36 |
