Memory or computing power
Old   February 4, 2013, 06:29
Question Memory or computing power
Felix
Spookz is on a distinguished road
I am doing a heat transfer simulation of a tool placed in an autoclave.
The heat transfer is only through convection (no radiation) and the temperature in the autoclave is slowly rising.
Real simulation time is 28 minutes and the timestep is 0.001 s
The element count of the whole mesh is 9.5 Million elements.
Actually I just want to know what a system you would recommend for this job.
A system with much memory or a system with much computing power?
What is the average time a system should work on this job?
Thanks for any answer!
Spookz is offline   Reply With Quote
Old   February 4, 2013, 06:52
A fast CPU is the most important for CFD. And lots of them so you can run in parallel. Memory is less important, but you need enough memory the run in RAM. If you run out of RAM it is a disaster, but if you have enough RAM to run then more RAM makes no difference. But pre- and post processing can require lots of RAM, more RAM than the solver in some cases.
I cannot estimate average time, it varies by so many things.
How do you know the time step size is 0.001s and the mesh is 9.5M elements? Did you just guess that or did you actually determine what was required?
Old   February 4, 2013, 07:08
Felix
Thanks for the answer!
I determined the element count by some test simulations and by decreasing element size. With a timestep of 0.001 I got convergence.
Would you say a system with 24 CPU-cores (each 2.9 Ghz) and 10 GB RAM is enough?
I need to finish this simulation in less than a month
Old   February 4, 2013, 17:25
So did you do a sensitivity analysis to determine the mesh size? It sounds like you did not do a sensitivity analysis to set the time step size. This means you will spend the next month finishing your simulation and will get a very inaccurate answer. Does not sound very constructive to me.
You need to do a sensitivity study on mesh size, time step size, convergence tolerance and any other tunable parameter first. Once you know all these parameters then you know how big the simulation will be and then you can arrange for a computer big enough to solve it in the time you have available.
If you do this backwards you will get a simulation finished on time whose results are meaningless.
Memory demand for parallel computing (unstructured grid) manely Main CFD Forum 0 November 12, 2010 08:46
How to optimize the memory usage when using FEM vasilis Main CFD Forum 11 August 25, 2009 00:57
Memory error? Young CFX 3 September 30, 2008 12:33
Wind Power Frank Grassi FLUENT 0 October 12, 2007 12:20
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 18:50
