Conjugate heat transfer
Old   January 25, 2013, 07:26
Smile Conjugate heat transfer
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hello sir,
While solving conjugate heat transfer problem i am getting following error
| Convergence History |
| Writing transient file 0_full.trn |
| Name : Transient Results 1 |
| Type : Standard |
| Option : Time Interval |
| Timestepping Information |
| Timestep | RMS Courant Number | Max Courant Number |
| 1.0000E-02 | 0.00 | 0.00 |
TIME STEP = 1 SIMULATION TIME = 1.0000E-02 CPU SECONDS = 1.398E+02
COEFFICIENT LOOP ITERATION = 1 CPU SECONDS = 1.398E+02
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom-CAVITY | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK|
| V-Mom-CAVITY | 0.00 | 4.9E-01 | 9.9E-01 | 3.1E-06 OK|
| W-Mom-CAVITY | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK|
| P-Mass-CAVITY | 0.00 | 2.9E-07 | 2.8E-06 | 43.9 5.0E+02 F |
| U-Mom-ROOM | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK|
| V-Mom-ROOM | 0.00 | 1.1E-01 | 1.7E-01 | 1.2E-03 OK|
| W-Mom-ROOM | 0.00 | 0.0E+00 | 0.0E+00 | 0.0E+00 OK|
| P-Mass-ROOM | 0.00 | 2.3E-10 | 3.0E-09 | 43.2 1.8E+05 F |
| I-Radiation-CAVITY | 0.00 | 3.9E-08 | 5.1E-07 | 42.3 1.7E-01 ok|
| I-Radiation-ROOM | 0.00 | 2.7E-08 | 2.2E-07 | 6.8 7.8E-04 OK|
| I-Radiation-FACADE | | %SD Vol | %SD Sur | %Lost %Imbal |
| Full Spectrum | | 1.0E+02 | 1.0E+02 | 0.00 0.00 |
| I-Radiation-WALL | | %SD Vol | %SD Sur | %Lost %Imbal |
Slave: 2
Slave: 2
Slave: 2 +--------------------------------------------------------------------+
Slave: 2 | *** INSUFFICIENT MEMORY ALLOCATED *** |
Slave: 2 | |
Slave: 2 | ACTION REQUIRED : Increase the integer stack memory size. |
Slave: 2 | |
Slave: 2 | Details : |
Slave: 2 | Requested space : 34443 words |
Slave: 2 | Current allocated space : 16541265 words |
Slave: 2 | Current used space : 16511484 words |
Slave: 2 | Current free space : 29781 words |
Slave: 2 | Number of free areas : 2 |
Slave: 2 Fatal error generated in gKElSel
Slave: 2 Message :- FULL : Failed to make a data area for KElSel
Slave: 2 gKElSel called by :- gKSelEl
Slave: 4
Slave: 4
Slave: 4 +--------------------------------------------------------------------+
Slave: 4 | *** INSUFFICIENT MEMORY ALLOCATED *** |
Slave: 4 | |
Slave: 4 | ACTION REQUIRED : Increase the integer stack memory size. |
Slave: 4 | |
Slave: 4 | Details : |
Slave: 4 | Requested space : 247398 words |
Slave: 4 | Current allocated space : 17447562 words |
Slave: 4 | Current used space : 17127089 words |
Slave: 4 | Current free space : 320473 words |
Slave: 4 | Number of free areas : 3 |
Slave: 4 Fatal error generated in gKSelEl
Slave: 4 Message :- FULL : Failed to make a data area for KSelEl
Slave: 4 gKSelEl called by :- gKVxEl_ZN
Slave: 7
Slave: 7
Slave: 7 +--------------------------------------------------------------------+
Slave: 7 | *** INSUFFICIENT MEMORY ALLOCATED *** |
Slave: 7 | |
Slave: 7 | ACTION REQUIRED : Increase the integer stack memory size. |
Slave: 7 | |
Slave: 7 | Details : |
Slave: 7 | Requested space : 68790 words |
Slave: 7 | Current allocated space : 15872675 words |
Slave: 7 | Current used space : 15851107 words |
Slave: 7 | Current free space : 21568 words |
Slave: 7 | Number of free areas : 2 |
Slave: 7 Fatal error generated in gKSelEl
Slave: 7 Message :- FULL : Failed to make a data area for KSelEl
Slave: 7 gKSelEl called by :- gKVxEl_ZN
Slave: 8
Slave: 8
Slave: 8 +--------------------------------------------------------------------+
Slave: 8 | *** INSUFFICIENT MEMORY ALLOCATED *** |
Slave: 8 | |
Slave: 8 | ACTION REQUIRED : Increase the integer stack memory size. |
Slave: 8 | |
Slave: 8 | Details : |
Slave: 8 | Requested space : 1605 words |
Slave: 8 | Current allocated space : 16145495 words |
Slave: 8 | Current used space : 16144004 words |
Slave: 8 | Current free space : 1491 words |
Slave: 8 | Number of free areas : 2 |
Slave: 8 Fatal error generated in gFACE
Slave: 8 Message :- FULL : Failed to make a data area for FACE
Slave: 8 gFACE called by :- gKVxEl_ZN
Parallel run: Received message from slave
Slave partition : 2
Slave routine : ErrAction
Master location : RCVBUF,MSGTAG=1032
Message label : 001100279
Message follows below - :
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine gKElSel |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| G:\FACADES\ANALYSIS\POST\Unnamed_005: |
| 0_full.trn |
| The following user files have been saved in the directory |
| rad, mon |
| Warning! |
| After waiting for 60 seconds, 1 solver manager process(es) appear |
| not to have noticed that this run has ended. You may get errors |
| removing some files if they are still open in the solver manager. |
This run of the ANSYS CFX Solver has finished.
please help me
sunilpatil is offline   Reply With Quote
Old   January 25, 2013, 12:42
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
You should increase the integer stack memory size
It's in the advanced options of the solver manager. Also there are many threads on the forum so you can search them for more detail.
cdegroot is offline   Reply With Quote
conjegate, memory allocation
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid Rockda FLUENT 24 August 30, 2016 07:33
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Conjugate Heat Transfer in rhoPisoTwinParcelFoam jabecker OpenFOAM 0 June 23, 2011 10:19
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
