Timescale Update Frequency
Old   January 23, 2013, 15:09
Default Timescale Update Frequency
Willian
100tinela is on a distinguished road
Hi everyone,
I am trying to use 'Timescale Update Frequency' parameter to control the convergence of my steady state simulation. However, everytime I try to prescribe its value using CCL on CFX-Pre it just disappear on CFX-Solver and when I open CFX-Pre again it is not there. Has someone any idea of how I can fix it?
Below is an example of what I am trying to use.
CONVERGENCE CONTROL:
Length Scale Option = Conservative
Maximum Number of Iterations = 400
Minimum Number of Iterations = 1
Number of Timescale Updates = 2
Timescale Control = Auto Timescale
Timescale Factor = 1
Timescale Ramping Factor = 5
Timescale Update Frequency = 10
END
I appreciate any help!
100tinela is offline   Reply With Quote
Old   January 23, 2013, 18:04
Edmund Singer P.E.
singer1812 is on a distinguished road
Not sure what to say about it disspearing in the ccl, but are you running the solution and is it working correctly? Does the time update at the frequency you set? If so, dont worry about it.
singer1812 is offline   Reply With Quote
Old   January 23, 2013, 19:15
Willian
I forget to mention before, but I am also working on Workbench platform.
When I run my simulation it doesn't update the timescale as I've prescribed. Apparently the information is someway lost between CFX-Pre and CFX-Solver.
Of course, it works when I edit directly on CFX-Solver, but this way is not feasible in my case because I am working with multiple design points.
Old   January 24, 2013, 14:32
Willian
I still can't figure out why the parameter 'Timescale Update Frequency' is disappearing, but I've found another simple way of doing it. I created an expression for my 'Timescale Factor' like this one:
TscaleFactor=1+4*step(citern-10)
and I can use this Heaviside function to update my timescale as a function of the current timestep (citern).
Old   January 24, 2013, 18:25
Edmund Singer P.E.
It would seem to me, if you are that interested in that much control over the timescale, you should be using physical time scale and adjust it accordingly.
Old   January 25, 2013, 08:02
Willian
Ok, now I see it.
I really appreciate your help!
Determination of physical timescale Chander CFX 2 October 19, 2011 20:47
Timescale for rotating harware with long domains aerost CFX 1 July 21, 2010 00:42
Solid Timescale Control Parthipan CFX 2 August 24, 2007 11:07
Advice on Physical Timescale Oli CFX 0 January 16, 2007 11:41
SST in 2D? Jesper Sørensen CFX 16 December 23, 2006 09:40
