Problematic Geometry
Old   January 17, 2013, 09:59
Default Problematic Geometry
Marco Antonio
marcoymarc is on a distinguished road
Hello Guys.
I know there are several threads about problematic geometry and i tried some solutions with no result (different methods and smaller elements).
I want you to see my issue since it sounds very strange cfx mesher reports an error message only for 1 of the four elements i'm trying to mesh, since they are perfectly equal.
Again, sorry for my English.
Every suggest will be helpful.
Thank you
marcoymarc is offline   Reply With Quote
Old   January 17, 2013, 11:06
Marco Antonio
Well, if i take a single element and try to use a sweep method, everything works fine.
When i put em together and i define a sweep method for each one of them, i can't complete the meshing.
Consider that the four elements are placed in a parallelepiped (that's hidden in the linked jpg). I think there are some issues at the interface.
Any ideas?
Which method should i choose to mesh the "container"?
Old   January 17, 2013, 20:38
This should be asked on the ANSYS geometry and meshing forum.
Old   January 17, 2013, 21:18
Marco Antonio
Ghorrocks i did it. Even if the error suggested something else, i found a little issue in my CAD model and solved it redefining some bindings. Thank you anyway.
[DesignModeler] problem with import geometry from catia pavilion ANSYS Meshing & Geometry 1 November 23, 2012 11:45
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Problematic Geometry fatb0y CFX 15 October 13, 2010 18:17
Problematic geometry in Ansys Meshing ATOTA ANSYS Meshing & Geometry 1 October 9, 2010 12:51
[snappyHexMesh] SnappyHexMesh meshes inside and outside of an STL geometry villier OpenFOAM Meshing & Mesh Conversion 17 June 15, 2010 20:51
