January 12, 2013, 03:47 |
domain
dhiraj
Rep Power: 13 |
I am in a project to analyze the Heat Transfer in a tube with thickness. The fluid (gas) is flow from outer portion of the tube and fluid (steam) flows inside tube. The tube has thickness with solid (steel). I created mesh where i define inner face, outer face of tube and volume of thickness. The conditions are: for gas flow, two inlets with velocity (domain with gas inlet temperature) and outlet to atmospheric pressure. For steam flow, one inlet through tube with mass flow rate (domain with steam inlet temperature) and outlet with steam pressure. I leave the domain interface as default. Is this is correct? Because, I cant get expected result. The results shows, steam outlet temperature exactly as that of gas inlet and gas leave at same temperature of inlet gas. This is not possible. I dont know about how the domain interfaces are defined well. Is there is need to change in solver cfx. Thanks |
January 12, 2013, 08:39 |
Erik
Rep Power: 23 |
Make sure you have activated "heat transfer" in the interfaces tab, as chosen conservative interface flux on the domain interface side 1 and 2
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 06:57 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 02:54 |
CFX domain comparison | Kiat110616 | CFX | 4 | April 3, 2011 23:43 |
Material identification between a flow domain and a porous domain | Ervideiro | CFX | 1 | June 1, 2010 10:50 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
