January 11, 2013, 08:13 |
Questions for compressible flow
Roland Rakos
Rep Power: 17 |
I would like to complete a simple study. I have a 3D geometry which is a simple tube. There is a small choke in the middle of the tube. The main settings: Compressible flow (ideal gas) Inlet: Total pressure Outlet: Static pressure Steady state simulation Based on the theory of compressible flow, the critical pressure ratio: p_low/p_high=0,53, where the Mach number is 1. I would like to check these values in my simulation but I have some questions: 1. The Mach number is 1 in the choke, this is ok. But locally? Or in the full cross section? If I define a plane in the choke then in case of the critical pressure ratio: maxVal(Mach Number)@Plane 1 = 1 ? or massFlowAve(Mach Number)@Plane 1 = 1 ? 2. Where should I measure the p_low and p_high? 3. The measured pressure is Total Pressure or Static pressure? Regards Roland |
January 12, 2013, 11:22 |
Erik
Rep Power: 23 |
1: Relief valve and orifice calculations would leave me to believe that it would be the mass flow average, since they tell you how much flow you can flow through an orifice. This could be wrong though, I've never done these types of things with CFD, only hand calcs.
2: Measure them sufficiently far up and downstream from the orifice, past your vena contracta. I would plot a chart of pressure along the length, then choose your points with a low dP/dx that aren't in the immediate zone of the orifice. 3: Static pressure, as total pressure will include your dynamic head. |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
Questions About Surface-Tension Driven flow | moki | FLUENT | 2 | March 12, 2006 20:26 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 06:44 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
