tutorial doubt _Catalytic converter
Old   January 1, 2013, 05:25
Default tutorial doubt _Catalytic converter
Shashwat
shaswat is on a distinguished road
Dear friend
Please find the attached tutorial screen shot. I am confusing in the porous domain setting . please clarify my doubts.
In the porous domain, I can find three boundaries.
1. housing default
2. inlet side 2
3. outlet side 2
My doubts are in the inlet side 2 and outlet side 2
inlet side2 and outlet side 2 are interface between fluid and porous on porous part . I found that heat transfer option is adiabatic (default setting).
if the adiabatic condition is set, no heat transfer will be allowed.
Is the setting correct?
Kindly give your feedback
Thank you
shaswat is offline   Reply With Quote
Old   January 1, 2013, 12:31
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
The adiabatic condition on fluid-porous interfaces means there is no HT from the porous solid to the fluid outside the porous domain. There is still HT from the fluid in the porous domain to fluid outside the domain. Maybe not the most accurate assumption but it works for the purposes of the tutorial. In a real application you will want to work out a HT coefficient if you think there is significant HT from the solid at the interface.
cdegroot is offline   Reply With Quote
Old   January 2, 2013, 04:15
Govindaraju
kmgraju is on a distinguished road
Dear friend
Thank you so much for your clarification
Thank you once again
kmgraju is offline   Reply With Quote
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
Tutorial Doubt prince_pahariaa Main CFD Forum 0 May 30, 2012 03:20
[ICEM] Question about Shrink Wrap tutorial zhaohui ANSYS Meshing & Geometry 0 November 23, 2011 22:48
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 04:25
