difrrence betwin external and internal flow
Old   December 31, 2012, 11:20
Question difrrence betwin external and internal flow
hmasenger's Avatar
hamed
hmasenger is on a distinguished road
hi all
i have a question that it seems easy to answer at first but i think its not that much easy !.
I am modeling cavitation in a butterfly valve and i need to validate my CFX results by checking sigma (cavitation index) with experimental data
but the problem is that experimental data which are available ,are for external flows over hydrofoils and other submerged bodies, and now i don't know is it possible for me to use does data for the disk of butterfly valve which is in a wall bounded water domain in a pipe ?
in what circumstances flow over a butterfly valve's disk can be modeled as an external flow?
by the way i just need to know the sigma value over the disk and its not important to know what would happen to flow(eddy viscosity) just after the disk
can i just compare cfx results for sigma and experimental ones for external flows?
any help will be appreciated .
hmasenger is offline   Reply With Quote
Old   January 1, 2013, 18:51
Cavitation modelling is never simple. This is a very difficult problem and if you get accurate answers you are doing well.
If you have experimental data on hydrofoils and other sumerged bodies then I would model those and make sure you can model those accurately before moving to your flow. In terms of cavitation modelling it does not matter whether it is internal or external flow. But what does matter is details about the fluid such as impurities, dissolved air content and surface conditions - these make massive differences in cavitation modelling and is why it is so hard.
Modeling internal and external flow for a nozzle smschnob Main CFD Forum 1 November 11, 2010 18:12
Why Re is different for external and internal flow john FLUENT 3 June 14, 2007 04:53
Why Re is diff for external and internal flow? john Main CFD Forum 1 June 13, 2007 03:58
internal flow and external flow ? Pathway0320 FLUENT 1 November 17, 2006 04:37
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
