December 12, 2012, 09:17 |
Order of numerical scheme
Johannes Ringborn
Rep Power: 14 |
I did a 2nd order calculation of a laminar flow in CFX which followed a GCI study (refinement factor r=2, 3 grids, asymptotic range (1.001113)). I observed a rate of convergence of p=1.15. I expected a value a bit less than 2 due to numerical effects but can a value close to 1 still be correct? Thank you very much in advance! |
December 12, 2012, 17:26 |
Rep Power: 144 |
Yes. All the different bits of the equations can converge at different rates - advection could be second order, bit diffusion could be first, etc etc. So if I find I am in the asymptotic range p which is close then I am happy.
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result | gemini | Main CFD Forum | 12 | December 27, 2011 22:01 |
TVD scheme limitedLinear only first order accurate? | Rickard.Solsjo | OpenFOAM | 0 | July 7, 2011 05:53 |
Numerical viscosity due to the MUSCL and HLL coulpled scheme | sonsiest | Main CFD Forum | 0 | May 23, 2011 16:37 |
Higher order downwind scheme | jelmer | OpenFOAM Running, Solving & CFD | 4 | August 9, 2006 07:43 |
numerical scheme | ado | Main CFD Forum | 3 | October 12, 2000 09:20 |
