November 20, 2012, 14:21 |
Error in CFX-Pre
niru
Rep Power: 14 |
Once I finish CFX pre and click on solution. I get this error message. I am not able to proceed to the simulation run.
"The CFX Setup case file no longer exists. Continuing in an initial state." |
November 21, 2012, 10:17 |
Bruno
Rep Power: 21 |
Please add more details so people can help you.
November 21, 2012, 12:22 |
niru
Rep Power: 14 |
I am done with geometry and Meshing. Once I give input details in CFX-Pre and on clicking the solution part , I get an error saying that the
"The CFX Setup case file no longer exists. Continuing in an initial state." When I click CFX-Pre after this message , the details that I entered are missing and I am not able to run the simulation. This happens when I use CCL files also to give input details in CFX-Pre. Any idea as to why it is occuring? |
November 21, 2012, 12:27 |
Chris DeGroot
Rep Power: 18 |
Maybe the CCL file is telling Pre to read some information from a file that doesn't exist. Post the CCL if you want someone to take a look.
November 21, 2012, 12:29 |
Bruno
Rep Power: 21 |
Does that happen to every project or just a specific one?
Try saving your project before going into CFX. Also check if your path doesn't contain special characters, that is, keep is with [a-z][A-Z][0-9]. Also check the temp folders set by Workbench in 'Tools > Options'. |
cfx-pre interface, error |
Error while opening cfx file in cfx pre | pks126 | CFX | 9 | June 11, 2018 12:00 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 08:55 |
CFX Pre Domains for centrifugal pump | MechKim | CFX | 1 | September 24, 2012 09:06 |
CFX Pre Hide symmetry symbols | alvid | CFX | 2 | August 15, 2007 12:34 |
CFX 10 -pre and -post problams on Linux | Henry Liu | CFX | 3 | June 22, 2006 07:57 |
