Expression Error
Old   November 16, 2012, 08:54
Default Expression Error
stefan
stefan85r is on a distinguished road
I get this error when I want to use this expression:
probe(Total Mesh Displacement Y)@MP1
"Attempt to evaluate the CEL callback function 'probe'.
Although it is valid to create an expression that
uses such a function, the preprocessor does not support
its evaluation."
How can I get the "Total Mesh Displacement Y" from MP1 (MonitorPoint) to use in an another expression?
Thx
stefan85r is offline   Reply With Quote
Old   November 16, 2012, 09:20
Darren Leong
Darren Leong is on a distinguished road
It's a solution dependent function and will work fine when solving.
Just add the following to expression list, e.g. MP1LocY
For your other expression you can refer to the above by its expression name, e.g.
0[m]+MP1LocY
Instead of probe, you can also use ave i think
Darren Leong is offline   Reply With Quote
Old   November 16, 2012, 09:34
stefan
Thank you!
I will try it...
expression name: dy --> probe(Mesh Displacement Y)@MP1
expression name: Fy --> (-0.0011 [N m^-2]*dy^2+0.13 [N m^-1]*dy+95.419 [N])*1000
So the force (Fy) is depend on the high (opening Flap) and MP1 is fix on the Flap and moves up.
is that okay?
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
user defined function cfduser CFX 0 April 29, 2006 11:58
