Luigi Gurreri
Rep Power: 14 ![]() |
I have a transport equation of a scalar C in which it appears another (vectorial) variable i.
Also I have a differential equation of i: div(i)=0. Can I introduce and resolve this equation in Ansys CFX, or it supports only algebraic equations? |
Chris DeGroot
Rep Power: 17 ![]() |
Yes you can add additional transport equations in CFX.
Luigi Gurreri
The problem is that I haven't a transport equation, but an additional differential equation to be solved
Bruno
Rep Power: 21 ![]() |
Well,
![]() If that is the case, you can add and the following Expert Parameters to your simulation: Code:
FLOW: Flow Analysis 1 EXPERT PARAMETERS: solve energy = f solve fluids = f solve turbulence = f END END Cheers |
Luigi Gurreri
I have a transport equation of the variable C, in which there is a term containing i; also, I have the equation div i = 0. So, I have a system of two equation. I don't know how I can solve the latter equation
Bruno
You have four variables (C, ix, iy, iz) but only two equations. Aren't you missing two extra equations to close your problem?
Luigi Gurreri
I think you're right! Maybe I need others equations. I will study better my problem
add differential equation |
Adding adaptive mesh refinement to the forwardStep tutorial | AlphaSheep | OpenFOAM Running, Solving & CFD | 10 | August 3, 2019 14:40 |
chtMultiRegionFoam, adding a member to an existing class (regionProperties) | romain.h | OpenFOAM Running, Solving & CFD | 1 | October 10, 2012 15:05 |
