Slow convergence using mass flow BC
Old   November 6, 2012, 05:11
Default Slow convergence using mass flow BC
Vit Houst
vitulaaak is on a distinguished road
I have a problem, that when I use mass flow at outlet, the convergence is really slow. The change of the mass flow on the inlet is almost none and where pressure BC changed the mass flows in 50iterations, now it takes more than 300.
vitulaaak is offline   Reply With Quote
Old   November 6, 2012, 06:35
Have you read the boundary condition choice section in the CFX documentation? That describes what you need to know.
Otherwise, please post an image and your CCL file so we can understand what you are doing.
Old   November 6, 2012, 07:40
Vit Houst
Hello ghorrocks,
yes I did. The purpose is to simulate a centrifugal compressor. For this reason I need to switch between different boundary conditions definitions. For choke region i use static pressure on the outlet. as the compression curves starts to be flat, i start to use mass flow BC.
The problem is not that it would not converge, but that it takes really long time to change mass flow. I found the expert parameters defining the underrelaxation of the values for these cases. Does anyone have experience with these?
For reference I attached pictures from solver, showing all iterations. You can notice the change in the speed when BC pressure was defined and when mass flow.
Old   November 6, 2012, 18:11
I would not recommend fiddling with the under relaxation factors. It is highly unlikely they will help.
If the change is slow then you have to run a larger time step to push the change through the system. If you cannot run larger time steps by numeric stability then you need to improve mesh quality.
Old   November 7, 2012, 11:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Use average static pressure condition as it is equivalent to specified mass flow rate boundary condition and at the same you are defining pressure which is more logical to define. Search for the Chima paper in Journal of turbomachinery for more explanation.
I can explain in more detail as discussion progresses.
Simple static pressure condition is also good if the boundary is not too close to the trailing edge. Moreover check the mesh quality.
http://www.cfd-online.com/Forums/cfx...-pressure.html
Quote from above post
Originally Posted by Far View Post
so you are ruling out the uniform static pressure boundary condition if it is placed too close?
And from your discussion I also infer that average pressure static with zero blend factor should work good regardless of location of outlet boundary?
Mass flow is not a option !!! because some times we have to work with new designs and it is very hard to make map near choke conditions.
These posts may be useful for you:
http://www.cfd-online.com/Forums/cfx...machinery.html
http://www.cfd-online.com/Forums/cfx...-strategy.html
http://www.cfd-online.com/Forums/cfx...essor-map.html
Far is offline   Reply With Quote
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
Mass flow rate sepidecent CFX 0 August 9, 2011 01:15
2 Inlet Pres BC's and Out Mass Flow - Convergence SN Siemens 0 July 19, 2006 10:12
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 05:47
