CFX Boundary conditions
Old   October 23, 2012, 07:32
Default CFX Boundary conditions
Vit Houst
vitulaaak is on a distinguished road
I am modeling compressor in CFX.To prevent from switching boundary conditions, i tried to use opening on the outlet with pressure loss ( i would use outlet, but there is no such possibility to add pressure loss to this type of boundary).
when I use this approach, it sometime fall on overflow. To prevent from doing this I would like to do either:
1. specify different initialization file than current in workbench - I dont know how
2. specify a linear function of pressure loss vs. number of iterations
Could you please let me know, how it can be done.
V.
vitulaaak is offline   Reply With Quote
Old   October 23, 2012, 09:23
Vit Houst
I would add one point.
I know, how to initialize from initial conditions and not from current solution. Is there a way to initialize from last design point? This would probably be the preffered option.
Old   October 23, 2012, 16:50
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
You can initialize from any .res file, so it shouldn't be a problem to use the "last design point" as you put it. Do this in Solver Manager when you set up the case.
With regards to having a pressure loss that is a function of the iteration number, use a CEL expression.
cdegroot is offline   Reply With Quote
Old   October 24, 2012, 09:53
Vit Houst
that was exactly what I was looking for, but when you check the options that ansys offers you in the expressions, iteration number is not there. Anyway I found it in the help, so now it seems to work fine.
Old   October 25, 2012, 13:13
Bruno
brunoc is on a distinguished road
Why do you need to specify a pressure loss at the outlet? Could you explain us what is it you're modelling at the outlet?
brunoc is offline   Reply With Quote
Old   October 26, 2012, 07:20
Vit Houst
Hello,the reason is following:
You can either specify mass flow or static pressure at the outlet. These conditions are not always met and you can get simulation problem...by specifying a pressure loss further downstream the compressor you basicaly try to simulate the reality. When you measure compressor performance you throttle the exit to get to different operating conditions. The other possibility would be to specify a variable porosity at the outlet to create again a pressure loss. This solution should be self sustainable.you should not need to swit h between different boundary conditions.
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Help with boundary conditions Dan CFX 0 April 3, 2006 12:32
