August 7, 2014, 10:29 |
I tried #15. Could you confirm it?
#21 | |
HYOSUK NAM
Rep Power: 12 |
Above images are not shown, please click the below links. https://drive.google.com/file/d/0B-Q...it?usp=sharing https://drive.google.com/file/d/0B-Q...it?usp=sharing Many Thanks HyoSuk |
August 7, 2014, 19:36 |
#22 |
Rep Power: 144 |
You seem to be defining 2 points in 3D space. WSS exists as a variable on the wall surface. So you need a line object on the wall surface, not in 3D space. You can generate this from the intersection of a plane with the wall surface (or many other means).
August 8, 2014, 10:18 |
#23 |
Edmund Singer P.E.
Rep Power: 21 |
Glenn, regarding your method. Wouldnt it have been easier to create an additional variable WSS*Normal.
Plot that on the surface. Put your line on the surface. Pull out the additional variable values that lie on the line? |
August 9, 2014, 06:59 |
#24 |
Rep Power: 144 |
Yes, that probably would be easier - thanks for the tip.
August 9, 2014, 13:18 |
Dear Glenn and Edmund
#25 | |
HYOSUK NAM
Rep Power: 12 |
I am a doctor so I have little knowledge about fluid dynamics. I want to measure wall shear stress on the stenotic artery. According to your reply, I have to draw line on the wall not to 3D model. Does It mean that I have to draw line on the mesh before simulation? And, dear Endmund, what is WSS*Normal? How can I use in CFX? Thanks |
August 10, 2014, 06:50 |
#26 |
Rep Power: 144 |
No, you just need to generate a line object which lies on the wall boundary. There are lots of ways of doing this:
* you could draw a line in 3D space and project it onto the surface * you could get the intersection of a surface and the wall surface * you could extract a contour of some description on the wall surface * many others... All these methods generate a line object which lies on the wall. Now you have a line object on the wall you should be able to extract wall variables (like wall shear stress) along this line. Normal is a variable defined at surfaces, where it gives the surface normal at that point. Look it up the CFX Reference manual for further information. |
August 10, 2014, 10:55 |
Thanks Glenn
#27 |
HYOSUK NAM
Rep Power: 12 |
I will do according to your comments.
I appreciate your kindness. Thanks HyoSuk |
August 19, 2014, 10:39 |
#28 |
pjohhn
Rep Power: 12 |
Hi mrkmrk,
I tried to implement the tangential wall shear stress in CFD post along the curved surface as you mentioned i.e. tangential wall shear stress vector= T-((T.N)N) I created three Tx,Ty,Tz expressions with Normal X, Normal Y and Normal Z and then created a tangential wall shear stress vector in variable list. However, I didn't get the negative tangential wall shear stress value. Can you please suggest how did you solve the same, as I am also intersted in the negative co-efficient of friction for the separation zone? |
August 19, 2014, 18:08 |
#29 |
David
Rep Power: 13 |
I calculated it on a curve and not a surface, how did you create Tx?(type your expression) |
August 20, 2014, 06:29 |
#30 |
pjohhn
Rep Power: 12 |
I calculated Tx with consideration of Normal X. I think what I did was mistake since we get the vector of shear stress from the CFD post. I used
Tx = Tx - (Tx.N)N) and it is wrong. I think when we apply tangential wall shear stress vector= T-((T.N)N), it will be same as the wall shear stress vector obtained from the CFD post or not?? Actually I also want along the curve..I have the pipe bend and over the symmetry plane boundary I want to have the co efficient of friction. Can you pls. tell me how did you calculated along the curve?? By considering the dot product of TX, Ty, Tz and the unit tangent vector pointing towards the flow direction? |
August 20, 2014, 11:24 |
#31 |
David
Rep Power: 13 |
I think in the CFD post "Wall Shear" variable represents wall shear stress vector that is always tangential to your surface but when you want its contour on a surface CFD post calculates only the magnitude of this vector that is always positive. If you want negative values of tangential wall shear stress, you should calculate it on a line/curve. For calculating tangential wall shear stress on a curve you should export this curve wall shear X, Y, Z data and then process them with a mathematical software (like Maple or Matlab) by the method that Glenn said in post#15.
August 25, 2014, 03:23 |
#32 |
pjohhn
Rep Power: 12 |
Thanks for your suggestion...The problem is solved now...:-)
April 1, 2015, 11:09 |
#33 |
NC
Rep Power: 11 |
How do you do that projection? I've looked and looked in vain in the documentation and elsewhere. (I actually want to project a point, but figure it's the same process.)
June 18, 2016, 21:15 |
#34 |
No excuse
Dear all,
I want to calculate wall shear stress in a steady state condition for laminar flow. How did you calculate it? Thanks in advance |
June 20, 2016, 10:34 |
#35 |
xin
Rep Power: 13 |
June 20, 2016, 12:43 |
#36 |
No excuse
July 12, 2016, 05:12 |
dear all
#37 |
Tamilnadu
how to create a intersection for two different parts in one plane
Measuring wall shear stress in bend pipe | liguifan | OpenFOAM | 70 | December 9, 2015 04:49 |
What is wall shear stress and shear strain rate? | warlocklw | Main CFD Forum | 2 | May 21, 2012 07:16 |
Wall shear stress | GamFlu | Main CFD Forum | 0 | June 11, 2011 05:33 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 13:03 |
relationship between wall shear stress and TKE | winter | FLUENT | 0 | December 11, 2007 18:11 |
