October 17, 2012, 03:26 |
Convergence problems turbo machinary
baddy
Rep Power: 14 |
hi,
i have a modell devided by 4 (90°) my MAX residuals are never under e-02. coupled rotating domain with stationary domain. air as ideal gas / total energy. physical time step 0.00001. interface between domains frozen rotor. can some one help me to get an convergence? thanx |
October 17, 2012, 05:08 |
Matthias Voß
Rep Power: 20 |
export the residuals (CFX-Pre) within the normal result files->solve again starting from your current solution and run just 1 Iter.->visualize the "highest" residuals in CFX-Post as a Isovolume --> i bet you´ll find some mesh issue OR some trans. effect
Is there a part. reason for chossing such a small physical TS? neewbie |
October 17, 2012, 05:16 |
baddy
Rep Power: 14 |
Yes if not such a ts, error comes 'overflow'
October 17, 2012, 05:27 |
Matthias Voß
Rep Power: 20 |
tried 'local' timestepping?
October 17, 2012, 05:29 |
baddy
Rep Power: 14 |
thanx for quick answers
no physical ts |
October 17, 2012, 07:46 |
Christoph
Rep Power: 18 |
what kind of turbomachinery? turbine?
you'vve to provide more information to achieve serious advice. as it is a stationary simulation, it's not a "real" timestep, but rather a pseudo. if your mesh has good quality, stat/rot interface is well placed and there were no setup failure (e.g. neglect wall as counter-rotating etc.), try to use a 1st order scheme (also turbulence) or try to use a coarse mesh to achieve convergence. is there also a diffuser anywhere?! |
October 17, 2012, 07:59 |
baddy
Rep Power: 14 |
yes it is a stationary simulation. no turbine. it is a asynchrone machine. i am solving the inner convetive cooling... air produces also heat. my mesh has a good quality but could be better. the geo is very difficult. the inter face i ok ( frozen rotor) no countering wall exist.
October 17, 2012, 11:33 |
ali
Rep Power: 15 |
can you send an image of your residuals?
are they like a smooth line or not? are they changing? and also you should check your results if they are logical residual is not a big deal |
October 18, 2012, 06:16 |
#9 |
baddy
Rep Power: 14 |
Which wall function should be taken? CFX makes it automatically??
what about les ? |
October 18, 2012, 06:54 |
#10 | |
Christoph
Rep Power: 18 |
One for sure: you need a very good mesh for this kind of simulation. y+ should be <1! that means, that you can't use a wall function. use sst as turbulence model and ensure, that your near-wall boundary layer is resolved accurate. regarding heat transfer issues, you have to be meticulous about that! y+ values currently? please provide some pics |
October 18, 2012, 18:18 |
#11 |
Rep Power: 144 |
Sorry to jump in late but the original question here is an FAQ: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
October 19, 2012, 02:55 |
#12 |
baddy
Rep Power: 14 |
ghorrocks i read this time ago. i did not ask before reding this. so i am refinig the mesh.
October 22, 2012, 06:40 |
#13 |
Christoph
Rep Power: 18 |
As I mentioned before (after looking at your residuals), you have problems with energy equation. It's highly proable that you didn't resolve boundary layer accurate and/or use heat model, that doesn't apply to real physics.
But it's difficult to give serious advice without further details. What kind of mesh do you use? what y+ values do you have? which setup do you use? |
October 23, 2012, 06:03 |
#14 |
baddy
Rep Power: 14 |
my mesh is patially stuctured, partially unstructured. but some geom is nor possible to mesh it with icem (to much time). i do not unterstand the setup? what do you mean with this?
my physical ts is 1*e-6 now is this ok or to small? |
Fluent Convergence Problems | Vidya | FLUENT | 24 | January 1, 2016 14:01 |
Convergence problems!!! | king lui | FLUENT | 11 | June 15, 2011 11:30 |
NACA0012 Convergence Problems | StudentAndrew | CFX | 6 | November 21, 2005 07:49 |
convergence problems | jeremy | FLUENT | 7 | May 30, 2002 07:41 |
convergence problems | david aquilina | Siemens | 4 | October 27, 2000 10:18 |
