Rep Power: 15 ![]() |
I'd like to evaluate the heat flux through a plane which I create using the "Location" tool in CFD Post (within a solid domain) - but Post says "Heat Flux is not available on 'Plane 1'.". Is there any possibility to evaluate the heat flux at positions where no geometric boundary is located? Regards Hugo |
Marco Correa
Rep Power: 13 ![]() |
I'm having the very same problem. Any idea? Regards |
Nandish
Rep Power: 14 ![]() |
Have you figured out how to plot heat flux on a plane?
Thanks in advance |
hamed
Rep Power: 17 ![]() |
did u select heat flux as result in output control in cfx pre?
Erik
Rep Power: 23 ![]() |
How would you have heat flux without a surface transferring heat? It will be zero across some plane in the fluid without a boundary to transfer the heat.
Describe Heat Flux mathematically and you will see what I mean. |
Calculating heat flux | hugo17 | OpenFOAM Post-Processing | 4 | May 27, 2015 12:47 |
How to set the Heat Flux boundary condition at Outlet | creddy_trddc | CFX | 3 | September 21, 2011 07:44 |
how to impose experimental dat as boundary conditi | Rogerio Fernandes Brito | FLUENT | 14 | November 25, 2008 05:47 |
Wall heat flux | cujo | CFX | 3 | November 6, 2002 03:43 |
Heat Transfer Coeff. at Heat Flux Boundary | Rushyen | CFX | 6 | January 18, 2001 05:09 |
